Using dot brakes wi...
[Closed] Using dot brakes with mineral oil?
 Jerm
Is there a reason why brakes designed for dot fluid can't be used with mineral oil instead? I understand why it won't work the other way round given how corrosive dot fluid is but given that mineral oil isn't harmful, what would be the issue? I ask because I fancy trying sram road levers with different callipers.I know Hope mentioned producing some but have heard nothing since and it would be easier if cheap shimano ones worked. Also, if Hope were going to do after-market callipers, it would seem to be simpler to make one if they could rather than a variety.
Posted : 22/04/2017 7:15 am
It will swell and ruin the seals.
Hope make two different road calipers because of this.
Well, that and piston ratios. Either way, the two fluids are not interchangeable either way around.
Posted : 22/04/2017 7:25 am
Mineral oil is oil like alkanes
DoT fluid is a mix of synthetic compounds like glycol ethers.
So no you can't interchange them.
Posted : 22/04/2017 8:19 am
Yeh it's the seals that are incompatible. Made of different material to work with the different types of oil to stop swelling etc.
Ratios have nothing to do with it, a hydraulic ratio doesn't change when you change the fluid, it's created by the difference in piston diameter.
Posted : 22/04/2017 8:33 am
 kilo
Are the hope ones available yet?
Posted : 22/04/2017 8:36 am
As mentioned above, the Hope callipers for Sram and Shimano are different, different seals and different piston sizes and volumes. The calliper has to work with the reservoir volume.
 Jerm
Thanks for the answers.I thought there must be a reason though it would not appear to be beyond the wit of man to make different rubber seals for the same calliper. As for piston sizes, if they were similar diameters I would have thought they would behave similarly.
Posted : 22/04/2017 8:53 am
Similar piston sizes will behave similarly. The same piston sizes with behave the same.
However, it can be a fine line between working and not working.
The Hope road calipers come in two types because of seals AND pistons. Otherwise, they'd only make one caliper and fit different seals.
Thanks!
Posted : 22/04/2017 9:32 am
I'm sure you could make different seals to allow the different oils to be used in the same calipers.
Problem would be inability to tell what you had and ensuing warranty and injury claims when brake seals started failing due to oil mix. Physical exterior difference makes it easy to tell even if company uses same internal with different seals...
Posted : 22/04/2017 10:26 am
Erm, do SRAM and Shimano use different fluid?
Posted : 22/04/2017 10:43 am
Yes, shimano is proprietary mineral oil, sram is DOT fluid.
Also, despite the comments above, both road calipers push different amount of fluid, enough to justify producing two different calipers.
I asked how they got around the fluid difference when they first released these. The answer was, they didn't, they had to produce 2 version but as they pushed different volumes of fluid, they had to anyway.
Posted : 22/04/2017 11:23 am
yes.
Posted : 22/04/2017 11:24 am
Yes
Posted : 22/04/2017 11:49 am
yes.
Well I'd better remember that. Thanks.
Posted : 22/04/2017 11:57 am
Slight thread drift:is there any technical reason for different brakes using different fluids? Or is it just brand preference?
Posted : 22/04/2017 5:22 pm
This is a good read...
http://www.epicbleedsolutions.com/blog/dot-brake-fluid-vs-mineral-oil/
Posted : 22/04/2017 5:35 pm
Primarily higher boiling point in DOT 5.1, less brake fade (in theory). Less compressible so less spongy (in theory, so long as well bled).
Noting that DOT 5 is a different thing and you should never put DOT 5 in DOT 5.1 brakes (4 is okay though, but has a lower boiling point).
DOT glycol based stuff are hygroscopic so absorbs water from air moisture which can mess it up.
Posted : 22/04/2017 6:03 pm
Mineral oil is more stable and non corrosive - but goes thick in the cold.
Its interesting that Shimano and Citroen are the only folk I know who use mineral oil and citroen have to as its all part of a hydraulic system
Posted : 22/04/2017 6:35 pm
Errm and Magura and Clarks and Tectro...
Posted : 22/04/2017 7:13 pm
 JAG
Post 1980 Rolls Royce also use Mineral oil 8)
[url= http://www.flyingspares.com/shop/rolls-royce-spirit-spur-bentley-turbo-mulsanne/brakes/brake-fluid/mineral-brake-fluid-1-litre-bottle-ut13741pap.html ]Rolls Royce Brake Fluid[/url]
Posted : 22/04/2017 10:06 pm
