Using a crud guard ...
[Closed] Using a crud guard on a full sus frame (seat up/down solution at last)
A few months ago i was musing about sorting a bracket to mount a crud guard on a full sus as close to the wheel as possible but with the ability to move the seat up and down. As it stood mine was 210mm up the seatpost and very useless!
The travel is 140mm so i wanted the guard 150mm above the tyre, if i did that then i could not put the seatpost down on long rocky peak downhills - GRRRRR
I contemplated many solutions including designing anew bracket, until someone mentioned mounting it on a gravity dropper. Then the idea blossomed!!
I purchased a 27.2 - 31.8mm seatpost shim and a 31.8mm qr (total cost £7)
This is what i came up with:
[b]Seat up[/b]
[b]Seat down[/b]
Undo 2 QRs and drop seat post, when at the bottom of the hill, seat back up and the crudguard is still as close to the wheel as possible - static at 150mm form the tyre tread! WINNER!
Posted : 08/01/2010 6:05 pm
Bloody brilliant thinking, well done!
Posted : 08/01/2010 6:42 pm
Cant you just leave the seatpost up?
you should know the rules by now,seapost up,helmets off. 😉
Posted : 08/01/2010 6:47 pm
What a flaff.
Posted : 08/01/2010 6:48 pm
 J0N
Solution looking for a problem!
Posted : 08/01/2010 6:52 pm
lol at blower
htf is it a faff - 2qrs
jon - whatever
Does the shim insert into the frame with the seatpost? Or does only the seatpost go into the frame?
Posted : 08/01/2010 6:56 pm
Might not be enough need to justify full production and everyone having one. However, Rob has come up with an elegant and simple solution to something that he has issue with. I like it. Well done mate.
james - Member
Posted 4 minutes ago # Report-Post
Seatpost goes into the frame through the shim, the shim stays put - fixes the mudguard height 🙂
Posted : 08/01/2010 7:01 pm
Onzadog - Member
jon et al
Posted : 08/01/2010 7:02 pm
good effort, simple solution.
good design is intelligence made visible (or something)
Posted : 08/01/2010 7:11 pm
yep ill give the lad credit there..
Posted : 08/01/2010 7:16 pm
Posted : 08/01/2010 7:22 pm
Nice work Rob.
Often wondered how I would do that if I could be bothered to use a rear gaurd.
Posted : 08/01/2010 7:30 pm
 igm
I use a [url= http://www.evanscycles.com/products/sks/x-blade-mtb-mudguard-ec005804 ]SKS X-blade[/url] which I attach to the frame. Play with the mounts and you get enough height over the rear wheel. If you are really tight for space, mount the piece that attaches to the bike upside down (it unbolts).
Sorted.
Posted : 08/01/2010 7:43 pm
hmmm - £7 or £20?
Posted : 08/01/2010 7:54 pm
How far does the shim go into the seat tube?
Posted : 08/01/2010 8:00 pm
I'd imagine the shim stays on top of the lower QR, with the other one clamping the top of the shim to stop it rotating.
Nice
Posted : 08/01/2010 8:02 pm
Your drawer is on the piss
Posted : 08/01/2010 8:07 pm
Explosion In a Spaghetti Factory - Member
Posted 6 minutes ago # Report-Post
Shim is the same outside diameter as the seat tube (31.8) so sits on top of that. Seat post fits inside the shim (and seatpost of course) at 27.2
The thick silver rim is the thickest bit of the shim that sists on top of the seat tube
Posted : 08/01/2010 8:08 pm
That's all well and good but why have you got a jar of instant coffee in your kitchen?
That's worthy of a stoning on here. 😉
Posted : 08/01/2010 8:15 pm
cos its easy and i am not a "coffee (S)knob"
Posted : 08/01/2010 8:19 pm
Posted : 08/01/2010 8:22 pm
I like that, is an elegant bit of thinking.
How much shim is inside the frame? That would be the only thing concerning me.
Posted : 08/01/2010 8:23 pm
none
Posted : 08/01/2010 8:25 pm
seat post is a 27.2 and teh correct size for the frame - the shim is essentially a sleeve OVER the seatpost and NOT into the seat tube. The shim is QR clamped ONTO the seatpost
Posted : 08/01/2010 8:26 pm
i cut my rear guard at one side then just bolted it onto my seat tube. took all of 5 mins. easy.
Posted : 08/01/2010 8:29 pm
Neat!
Does it spin if you hit the end of the mudguard? I found you needed em pretty tight to avoid that.
Nice solution young Robert 😉
Posted : 08/01/2010 8:30 pm
Dur! Of course - in that case it's even nicer than i thought.
ooOOoo - Member
Neat!
No because top QR holds the guard in place 🙂
Posted : 08/01/2010 8:31 pm
IGMC
Posted : 08/01/2010 8:34 pm
 igm
Rob - Member
hmmm - £7 or £20?
You can buy a Crud Guard, a shim and a spare QR seat clamp for £7? Well done.
Don't get me wrong, it's a good solution if you have already bought the Crud Guard, but I didn't.
Posted : 08/01/2010 10:04 pm
i like it. don't use mud guards but when i have i've found this a problem.
Posted : 08/01/2010 10:24 pm
I am confused. You need to drop the seatpost by 210mm?
Most folk drop it 3-4", having the crudcatcher go up and down by this amount is not fatal.
That said, you've solved your problem...
Posted : 08/01/2010 10:31 pm
Rob - Member
cos its easy and i [s]am not a "coffee (S)knob"[/s] have no sense of hunour
[b] IN BOLD IN CASE YOU DON'T SEE IT[/b] 😉
Posted : 08/01/2010 10:37 pm
So you undo both QRs when you drop the seat post?
If thats the case, wouldn't it be easier to fashion a QR for the rear mudguard and do away with the shim? How about a shim that goes outside the seat-tube, so is clamped by the lower QR, then you wouldn't need the top QR?
Posted : 08/01/2010 10:54 pm
the shim means that the mudguard is ALWAYS at the most optimum height. Otherwise to do this you would have to mark the post in 2 places. This is far more simple.
Posted : 09/01/2010 9:58 am
al the seat post drops by 5". the lowest that the bracket can mount is 70mm from the bottom of the post to clear the tyre at full compression, bracket is 30mm deep, so available drop height is the remaining 5"
Posted : 09/01/2010 10:09 am
Glad that I don't need either a rear mud guard, or to drop my seat post. That's almost as bad as home brew lights 😉
Posted : 09/01/2010 10:18 am
*cough*
Other brands of mudguard are available and [i]might[/i] just have their own QR built in
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=22989 ]CycraGuard[/url]
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=25803 ]SKS[/url]
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=32474 ]Topeak[/url]
*cough*
Posted : 09/01/2010 11:42 am
But do not get around having it at the optimum height without marking the seatpost in separate places
Posted : 09/01/2010 11:44 am
My way is fool proof and always has the guard at a fixed height. You are never moving it up/down the post. The post simply moves inside the shim up and down. Essentially its just an extension of the seat tube.
Oh and tootall their are other brands of cough medicine available!!
Posted : 09/01/2010 11:47 am
Rob, i think its ace. you could have invented a cure for AIDs and this lot would still find fault
Posted : 09/01/2010 11:48 am
SKS on a Gravity Dropper does the same for me
Posted : 09/01/2010 11:49 am
All well and good, trouble is those crud guards are; a) possibly the ugliest things in the world, and b) don't actually work that well anyway. Waterproof shorts are the way forward.
Each to their own.
Edit, oh hang on, you ride a Cannondale, ignore point a, it's not applicable in your case... 🙂
Posted : 09/01/2010 11:51 am
I'm a waterproof shorts man (though I'll use guards on the race bike for long shitty weather races, but I don't play with the height on that) but that is a neat solution rob.
If it's any interest to you then USE make shims in black to neaten it up a bit.
Posted : 09/01/2010 11:53 am
onion - Premier Member
Posted 5 minutes ago # Report-Post
FFS - if i had a gravity dropper still it would be no problem - but as they way the same as a cold war submarine i got rid!
Posted : 09/01/2010 11:55 am
I ordered a black one luke but CRC sent me silver 🙁
Black paint this arvo!!
Oh, and mudguards that mount with QRs like Topeak and SKS are bloody awful. Go down a rough descent and they end up on a wonk, no matter how clampbustingly tight you do them up.
Posted : 09/01/2010 11:56 am
S_O - you have limp wrists. I've never had a problem with the SKS one that I've ridden with for several years
Posted : 09/01/2010 12:08 pm
SKS ones are found jettisoned round our area a lot - commuting mudguards at best!
Posted : 09/01/2010 1:03 pm
Rob - Member
Which just proves you're all limp-wristed round your way.
Bluddy soft suverners
Posted : 09/01/2010 1:08 pm
broken not fallen off
Posted : 09/01/2010 1:31 pm
those SKS QR's with the orange strapping are ****. rob, don't listen to this lot, your idea is spot on; it works for you and takes out loads of hassle. looks wise the silver is ok too.
Posted : 09/01/2010 1:54 pm
That is a very neat solution.
Nice work.
Posted : 09/01/2010 2:01 pm
Thanks all (bar a few knobbers as usual)
Posted : 09/01/2010 5:21 pm
Great solution with what you already had Rob - as an engineer myself I like your design and implementation. The moaners are just jealous.
Have to say, I don't bother with one myself - I'm in the waterproof shorts brigade. Doesn't mean I can't admire your solution though 🙂
Posted : 09/01/2010 5:34 pm
I like my waterproof shorts but find that without a guard they get really wet which runs off, down ya legs, into shoes/sox. No fun 🙁
Thanks BTW 🙂
Posted : 09/01/2010 5:36 pm
lol
Wish i thought of that. Still a flaff though and a elegant solution to a non problem.
Posted : 12/01/2010 5:38 pm
wtf is flaff? like a FAFF but spelt wrongly?
Posted : 12/01/2010 5:42 pm
Who says FAFF is spelt right! So it's a big FAFF as well.
Posted : 12/01/2010 5:50 pm
[url= http://www.google.co.uk/search?hl=en&defl=en&q=define:faff&ei=x7ZMS8ucIoey0gSS7-n4DQ&sa=X&oi=glossary_definition&ct=title&ved=0CAcQkAE ]Well the dictionary is usually a good start when spelling words.[/url]
Posted : 12/01/2010 5:52 pm
http://www.allwords.com/word-faff.html
Posted : 12/01/2010 5:53 pm
Oh and by the way question marks are used at the end of questions e.g.
redthunder - Member
Who says FAFF is spelt right[b]?[/b]
Posted : 12/01/2010 5:54 pm
Your so sensitive.
However, still a FLAFF and FAFF. Actually it's a bit like having a bowler hat with sleeves 😉
Posted : 12/01/2010 5:55 pm
[url= http://thesaurus.reference.com/browse/knob ]clicky red thunder[/url]
Posted : 12/01/2010 5:57 pm
Is that your middle name ?.
Posted : 12/01/2010 5:59 pm
pmsl
Posted : 12/01/2010 6:02 pm
not
What are going to achieve next...
World Peace 😉
spose you'll want a pat on the head for that as well. 🙄
Posted : 12/01/2010 6:07 pm
the aids cure i created is obviously working
Posted : 12/01/2010 6:22 pm
I solve the problem and save money by not having a rear mudguard. You get wet and muddy mountain biking anyway, unless you are doing it wrong. MTFU.
Posted : 12/01/2010 6:27 pm
Rob, It's brilliant, as is your sense of humour!
Posted : 12/01/2010 6:44 pm
Rob's the Jack Dee of Mountain Biking 😉
Posted : 12/01/2010 6:52 pm
suppose its better than being alan carrs less famous brother, wayne!
Posted : 12/01/2010 6:55 pm
Was that a Christmas cracker joke...quite good that one.
You are a side splitter 🙂 You'll be doing poetry next.
Posted : 12/01/2010 7:10 pm
Funny you mention christmas crackers, am i right in thinking that was the last thing you pulled?
Posted : 12/01/2010 7:15 pm
I'm Wayne Carr, so I'm pulling all the time 🙂
Posted : 12/01/2010 7:17 pm
