Upshift Issues, any...
[Closed] Upshift Issues, any suggestions?
[#9571642]
XT mech, shifter and 11-46 cassette: sticks when shifting from 1 to 2, 3, etc.
Anyone else get/got this??
Posted : 26/09/2017 3:06 pm
Top jockey wheel or cage fouling the cassette or restricting chain movement? If so can be fixed with B screw adjustment.
Posted : 26/09/2017 3:08 pm
How new are the cables?
When mine get sticky on my commuter I give them a wipe with some grease (or reverb fluid round the loop) and they normally come back to life for a bit.
Posted : 26/09/2017 3:10 pm
Could be anything from the b screw not in enough to keep the mech and chain off the lower part of your cassette to dry inner cables or sticky shifter
Posted : 26/09/2017 3:11 pm
prawny - Member
Cables are 7 months old. Which loop? as it exits frame and loops round to the mech clamp?
Jef Wachowchow - Member
Adjust how... j-wheel nearer or further away from cassette?
Posted : 26/09/2017 3:38 pm
That's the one, don't think MTBs have one though anymore.
Are the gears indexed correctly the rest of the way through the cassette? Or is it sticky all the way up the block?
Posted : 26/09/2017 3:57 pm
Further away. Wind the screw in quarter turn at a time and test until free.
Posted : 26/09/2017 4:08 pm
Replace the cables, ..and make sure they are shimano inners & outers.
Posted : 26/09/2017 4:22 pm
dumbbot - Member
It's done it on and off from new, worse when they conditions are shitty.
Posted : 27/09/2017 9:05 am
POSTED 16 HOURS AGO # REPORT-POST
Will give that a go, cheers
Posted : 27/09/2017 9:06 am
prawny - Member
There is actually so i've blasted some gt85 in and run it up and down the cassette a few times - hopefully this and the b-tension rls will sort it.
The gears are indexed perfectly appart form the upshift from 1 to 2.
Posted : 27/09/2017 9:08 am
PP, did you get it working right? What was the issue in the end?
Posted : 02/10/2017 10:43 am
sticky clutch. my zee mech does it now and again with the clutch on.
smooth when you turn it off, sticky and notchy when you turn it back on.
Posted : 02/10/2017 11:03 am
Mine done exactly the same
New cable time been riding in some sh1t weather so the inner and outer will be caked in gunk
Posted : 03/10/2017 8:26 am
