Upgrade Fox elite t...
[Closed] Upgrade Fox elite to kashima
I know that there is no performance advantage and that it is only aesthetic, but how much would it cost to change a black Elite DPX2 to Kashima coated?
Posted : 17/10/2020 7:31 pm
Probably cheaper to sell yours and buy a DPX2 factory shock.
I sold mine for £280 a few weeks back, so a elite DPX2 would probably fetch £200 or so used.
The air can can be changed easily but I think the lower/inner body would need to go to fox/silverfish as it'll need nitrogen charging, as it's the damper body.
You know the kashima on the shock doesn't match the seatpost/forks, don't you?
Posted : 17/10/2020 7:54 pm
You know the kashima on the shock doesn’t match the seatpost/forks, don’t you?
Why is this? It makes my teeth itch.
Posted : 17/10/2020 8:37 pm
Stanchion tubes and seat posts are 7000 series aluminum, shock bodies and sleeves are 6000 series, Kashima Coat is a form of anodizing and the final color is affected by the base material underneath.
That's from Fox themselves (Pinkbike ask us anything).
Posted : 17/10/2020 8:43 pm
chestrockwell
I've seen forks where the kashima on one leg doesn't match the other. I think it's just that rather than being a really solid colour, the coating is the brown/gold but the brightness is from the aluminium shining through. So the longer it spends in the bath, or whatever, the darker or lighter it is. A lot of anodising's like that- I got a frame part reanodised by stevetheanodiser after it broke and I had to send him the original so that he could get the shade perfectly the same.
Posted : 17/10/2020 9:19 pm
Get a coil shock and end the DPX2 madness ;o)
Posted : 17/10/2020 9:24 pm
That's what I did, and why I sold mine 😀
Posted : 17/10/2020 10:49 pm
