Just got hold of a pair of BB7s for a great price....anything I need to know before I attempt to fit em, clearance at the back looks tight, what size discs can you run?
Any advice/ guidance appreciated before I start 🙂
Are you using drop bars/levers, and if so, are the bb7's the road versions?
I have a 160mm rotor in the back, more than enough on the road.
@cp - yep all good re bar / lever compatibility thks.
Just trying a 160 rotor in the back, frame clearance fine, but disc rubbing slightly within the calliper itself, presume I just need to play around with spacers .?
All good so far, thanks to all for the advice 🙂
I wouldn't ride less than 200mm
there's a chap done a blog entry with a really good, step by step guide. [url= http://www.twowheelblogs.com/avid-bb7-disc-brake-set-and-tuning ]here[/url]
Ooh ooh ooh.
Just the thread I needed to see..!
