Un-trendy Recommend...
[Closed] Un-trendy Recommendation required
[#3314050]
After a front mech for a build, has to be 28.6 and top pull.
Traditionally gone for Shimano, but can I use SRAM??
To work with 9psd Xt shifters (M770)
Is there much between a deore front mech and an XT? Or can I use SRAM if they're better?
Posted : 03/11/2011 9:14 pm
Shimano are better, they all shift the same, higher models just look prettier
Posted : 03/11/2011 9:16 pm
 cp
Used SRAM once - didn't last long at all. My experience of Shimano - the more you pay, the longer (marginally) they last, the nicer they look and the lighter they are.
The two main types of shimano mech are top swing (with a low clamp) and bottom swing (with a high clamp). Top swing have lots of pivots and thin plates, the shifting tends to be smooth and with a light action, but the durability, with all those pivots, isn't great & shifting suffers over time. Bottom swing are much longer lasting and are stiffer, but the action isn't as light top swing.
I had one incidence where a bottom swing mech clamp band fouled the lower bottle boss on the seat tube. If you have a low bottle mount, it would be worth getting a top swing.
Posted : 03/11/2011 9:29 pm
I still have a damaged thumb from using a SRAM front mech. way way stiffer than the big S, (and yes it was set-up correctly, mechanic by trade).
Shimano FTW
APF
Posted : 03/11/2011 9:57 pm
