ultegra 11 speed ch...
[Closed] ultegra 11 speed chainset with 10 speed set up ?
 snap
[#6879042]
HI ...Will a 11 chainset work with a 10 speed set up ?
dont really want to change everything to 11 speed , but need a new chainset and been offered a 11 speed at good money
Thanks in advance
Posted : 21/02/2015 12:56 pm
you should be able to get away with it ... 11 speed chain on a 10 speed
chainset on the other hand ... 😉
Posted : 21/02/2015 1:03 pm
It'll work just fine.
Posted : 21/02/2015 2:09 pm
Running both 9 and 10 speed on 11speed chainsets here, it'll be fine.
Posted : 21/02/2015 2:11 pm
The internal dimensions of the chains are the same so nothing to worry about
Posted : 21/02/2015 2:54 pm
I use an 11sp Ultegra crank with a 10sp SRAM Force/Rival group. Used the 11sp chainrings before I went oval, it worked flawlessly.
Posted : 21/02/2015 3:59 pm
