Tyre tread misalign...
[Closed] Tyre tread misaligned
[#4763284]
Just picked up a new Maxxis advantage to replace an existing worn version, I've noticed the tread is misaligned slightly (1-2mm) so the ramps etc don't quite match up in the middle whereas my current pair are perfect. Think this will this make any noticeable difference? Or should I just stick it on and forget about it...
Posted : 17/01/2013 7:27 pm
Can I have your bike(s) if, you know .... ?
Posted : 17/01/2013 7:33 pm
Ignore 🙂
Posted : 17/01/2013 7:34 pm
I'll try :p, just thought it might not wear/roll quite right when the chevrons are wonky + mild OCD!
Posted : 17/01/2013 7:41 pm
If you really had OCD it would be CDO as that puts the letters in alphabetical order as they should be of course.
Posted : 17/01/2013 7:44 pm
I noticed the same thing on some other, cheaper, re-branded tyres from the maxxis factory..
I can only ride sideways now like a crab 🙁
Posted : 17/01/2013 7:47 pm
Just put the wonky one on the back and SHRED !
Posted : 17/01/2013 7:54 pm
