Tyre contact on tur...
[Closed] Tyre contact on turbo trainers
[#3351596]
Set up new turbo and found rear wheel slips a bit, I try and use relatively little contact between the turbo and the tyre but realised I'm not sure how much pressure I should have between the two. Part of the problem is a flat spot in my tyre* and wonder whether throwing more money at a solution ie tyre or just increase contact until the area with the flat spot doesn't lose contact?
*possibly the wheel I guess
Posted : 14/11/2011 11:02 pm
Does the roller have a tension adjuster? Tighten it up and pull the roller closer to the tyre but watch out for heat build up blew apart a tyre (and the side of the rim) years ago when I was actually fit and used a trainer in the winter.
Or get one of the trainer specific tyres and stick it on an old cheap wheel.
Posted : 15/11/2011 12:27 am
Trainer specific tyre. Just enough tyre contact force so that it doesn't slip. Job done.
Posted : 15/11/2011 12:35 am
Damn it more money!
Posted : 15/11/2011 9:28 am
 kilo
On our turbo it is adjust till the roller is touching the tyre then two full turns of the adjusting wheel to get a good grip - what do the instructions say. never had to use a turbo tyre just an old wheel and tyre
Posted : 15/11/2011 9:51 am
yeah I just wonder if that is bit tight/overkill? might try swapping front and rear tyres and see if that helps
Posted : 15/11/2011 7:34 pm
Trainer specific tyre will save you money in the long run - turbos will eat through normal tyres in no time.
Posted : 15/11/2011 8:12 pm
I banged a roadie tyre on from Decathlon. So far so good
Posted : 15/11/2011 9:39 pm
