Twin chainring set ...
[Closed] Twin chainring set up
[#3114445]
Any recommendations for 28t and 40t (or 26/38) chainrings to fit a standard 4 arm (64 / 104) spider. Needs to be significantly cheaper than the xt double chainset on rose bikes at around 125 quid.
Currently using middleburn cranks so could use a duo setup but I've heard the shifting isn't the best.
Thanks
Posted : 05/09/2011 12:20 am
TA Specialites. Around £60 - £80 for a 28/40 set up. You may need to factor in some short chainring bolts though.
http://www.chickencycles.co.uk/index.php?cat=32&ord=2
Any good LBS will be able to get them (Chinook 40 middle and 28 inner).
Posted : 05/09/2011 12:26 am
Yep, TA Chinooks, look at Euro shops though - try Starbike. Cheaper and with better stock generally.
Posted : 05/09/2011 7:08 am
Thanks for that, starbike looks like a winner
Posted : 05/09/2011 10:33 am
