Turner 5 spot
[Closed] Turner 5 spot
[#320943]
Show me yours to keep me going until I get mine this weekend.
Posted : 19/02/2009 7:52 pm
[img] http://images.fotopic.net/?iid=ygvptf&outx=1024&quality=70 [/img]
Posted : 19/02/2009 8:28 pm
Lowey - Very nice but apparently no good anymore.
The DW link version is this years Emperor's New Clothes, Mr Turner said so.
Posted : 19/02/2009 8:30 pm
Posted : 19/02/2009 8:38 pm
^^^Now with a shorter 90mm stem...
Posted : 19/02/2009 8:39 pm
If I must..
Posted : 19/02/2009 8:41 pm
Posted : 19/02/2009 8:45 pm
^^^Now with a longer 90mm stem...
Posted : 19/02/2009 8:46 pm
Posted : 19/02/2009 8:50 pm
mrpink - are you running 160mm bolt throughs on yours?
was thinking of bigger forks for PDS this year but didnt know if the frame would take it.
Posted : 19/02/2009 8:55 pm
Yes,160mm talas with the 20mm bolt through,run it at 130mm most of the time with the 160 on the downs.Turner does not encourage it as you can flair the head tube( the DW model has been alterd to take 160mm forks)i don't abuse the frame fork with large jumps but i like the 36 for its stiffness and tracking.I also have a Talas 32 but it just feels better with the 36.
Posted : 19/02/2009 9:10 pm
Nice. Can't wait. Mines second hand HL one.
Posted : 19/02/2009 9:25 pm
go on then lol
Posted : 19/02/2009 9:30 pm
[img] http://images.fotopic.net/?iid=yv1bzv&outx=800&quality=70 [/img]
Posted : 19/02/2009 9:52 pm
Billybull. Saw yours today, thought it was a Kona.
Go play with your Kaffenbach!!!!
Posted : 19/02/2009 9:56 pm
[img] http://images.fotopic.net/?iid=yur39r&outx=800&quality=70 [/img]
Posted : 19/02/2009 11:12 pm
Now with better seatpost and seat. Just to bore you death, its an 08 frame, with an 08 rocker arm but 05 horstlink rear end. The Ultimate??
Started of as an 06 blue 5 spot but since i've snapped the front triangle, rockr arm and rear triangle its all been replaced
Posted : 19/02/2009 11:22 pm
Radoggair it sounds like Triggers brush! 😆
Posted : 19/02/2009 11:26 pm
Radoggair tell me more about this horst link rear end ive got an 08 spot
Posted : 19/02/2009 11:27 pm
Posted : 19/02/2009 11:31 pm
Not sure about the white rims
Posted : 19/02/2009 11:37 pm
Posted : 19/02/2009 11:42 pm
simples... crash your bike, go to bike shop saying you fell of a kerb. At that exact point the manager just happens to be selling his rear end of an 05 horstlink version of his 5 spot ( lucky i guess). Before Specialized patented the horstlink when turner paid zip for the use of it, the pivot (nearest the cassette) was on the lower swingarm, after 06 they moved it upto the bottom of the horizontal swingarm. Supposedly the bottom pivot helped during braking and controlled the rear alot better. Anyone else explain it better??
You can see on this pic that the pivot is on downtube of awingarm, previous was on the bottom swingarm
That makes sense??
Triggers brush?? i no comprende
Posted : 19/02/2009 11:49 pm
Hl end just bolts on. Tho having now ridden both personally i cant tell the difference between the two . Then again you may have to be a good rider to spot it lol
Posted : 19/02/2009 11:56 pm
