Tubeless Valves
[Closed] Tubeless Valves
[#5356919]
I made a mess of my rear tubeless valve, it was a stans valve in Crests. I do however have some bontrager valves kicking about-will there be any problems using these instead? They have a large metal shoulder with an O ring rather than just a rubber seal.
Also when they were in bonty wheels they were on thick bonty rim tape which was extra bulky around the valve
Posted : 23/07/2013 11:49 am
It may well work but you'll you'll know for sure without trying...
Posted : 23/07/2013 11:56 am
I looked at those in an LBS when I needed some in a hurry. Don't think they'll work as the well in the centre of a Stan's rim is quite curved.
Posted : 23/07/2013 12:22 pm
 RicB
Got an old inner tube? Cut some 1"sq squares, put a valve sized hole in the middle and use them to seal between valve and rim.
Posted : 23/07/2013 2:02 pm
Cut the valve out of it, use that...
Posted : 23/07/2013 2:04 pm
 RicB
not all inner tube valves have removeable cores, which can be useful in getting tyres to seat at the bead (much greater airflow). Also useful for topping up sealant.
Posted : 23/07/2013 2:09 pm
