retro fitting a gyr...
[Closed] retro fitting a gyro on a bmx
[#5356911]
now i'm a bit out of depth - got youngest a new bmx a few months back and as was doing 100% pump track with a view to racing didn't get one with a gyro - now doing stuff at indoor ramp centre and wants to spin bars - prob not good confident enough dodging scooters to go no brake picked up a gyro and the cables for not a lot but looking at forks only have a 3mm spacer below the stem - as far as I can see need a lot more room than that so cables pull ok? - so does that mean a new fork not cut down? any pointers to good diagrams helpful as no instructions with the one I bought
Posted : 23/07/2013 11:48 am
Does the frame have gyro tabs on it? (Cable stops to mount lower gyro cable)
Posted : 23/07/2013 12:00 pm
no but the kit includes these and the frame is drilled and tapped to take them and they look like will fit fine
Posted : 23/07/2013 12:10 pm
 LoCo
Is he running a front brake? if not just put a longer rear brake cable and out on as gyros are a pain in the bum.
Posted : 23/07/2013 12:17 pm
Have you got a hollow bolt stem cap as well? No point in running a Gyro with regular front brake cable routing - I'd do what LoCo suggests if that's the case.
Posted : 23/07/2013 12:19 pm
+1 for longer brake cable. Gyros are a pain.
You never know, he might learn too barspin/tailwhip both ways then. 😀
Posted : 23/07/2013 12:20 pm
no front brake
Posted : 23/07/2013 12:51 pm
Run a long rear cable.
Personally I'd only run a Gyro on a bike with both brakes.
I say that, I [i]did[/i] run a Gyro on a bike with both brakes for riding street, ramps, flat and stuff, but wouldn't have bothered if running a more street / dirt set-up with only a rear.
Posted : 23/07/2013 6:50 pm
