In what world is 46 quid for a bottle some tube and fittings good value?
The one where the option is chucking a £47 tyre...???
Seriously though ... most of my tyre/rim combo's go up no problems with a track pump.. quite a few I reckon would go up with a half decent hand pump... I've never tried since I've always had the track pump...
Then there is always one, I spent hours and hours on one tyre... probably 49 hours... so at £1/hr ???
What pressure is required to seat tubeless tyres onto the rims when using something like a compressor?
I tried 90psi with some Schwalbe Nobby Nics... no dice.
Edinburgh Bike Co did a £50 voucher for £25 a few months ago and I used it to buy the Specialized tubeless pump - so far so good and it works well. Personally speaking, for £25 it wasn't worth faffing around.
Yes I can seat all my tubeless tyres with a track pump, but sometimes I just CBA’d
I would have said the same until I came to fit Schwalbe G-Ones to my CX bike. They absolutely defeated my track pump and nearly defeated the compressor I borrowed! In the end, they were the reason why I bought a proper tubeless pump. Great tyres once fitted and not had a single issue with them since though 🙂
Has anyone in the history of tubeless tyres ever managed to mount a tyre tubeless with a track pump alone?
It does depend on the model of tyre but usually Bontrager tyres go up no problem with a track pump, you don't have to work particularly hard either. So long as one of the beads isn't caught on the valve then it's straightforward.
It can also vary from tyre to tyre: I put tubeless CX tyres on my singlespeed. Same tyres front and rear, same rims front and rear. The front inflated first time with just a track pump and stayed inflated without sealant. The rear took about five days to get sorted.
