Tubeless for Dirty ...
[Closed] Tubeless for Dirty Reiver?
 sb88
[#9873791]
Doing Dirty Reiver in April - will be using gravel tires in the 700 x 35c ballpark.
I have had tubeless on my CX bike for a year, with tubeless ready rims, tape and tyres and it worked great UNTIL I had to change my summer tyres to winter mud tyres the night before a race and the only way I could unseat the tyres was rocking the wheel with tyre in a vice.
I assume that the higher pressures run on a road-type bike, for riding to races and commuting, etc, would have seated the tyres particularly firmly... or not - I suppose the bead is either seated or not seated. Maybe it was just that combo of rim+tyre.
Anyhow... that's fine for a CX race where if you puncture you're out anyway and can get a lift to a train station, but in the middle of Northumberland it could be a disaster... While my rims and tyres will be tubeless ready, I'm tempted to just run tubes and carry loads of spares / put some Stans in the tubes...
Experiences?
Posted : 04/03/2018 11:13 am
Not had the problem you describe.
I will be going with a tubeless set up as last year and carrying a couple of tunes case of punctures.
Last year I can honestly I have never seen so many punctures on one ride. Or dropped water bottles.
Posted : 04/03/2018 2:50 pm
Tubeless is the next best thing to mandatory for the DR.
Posted : 04/03/2018 2:51 pm
How many tubes are you planning on carrying of you don't?
Posted : 04/03/2018 3:32 pm
Id be tempted to run tubeless at the DR and deal with the tyre/rim issue if and when it happens. Short of a catastrophic rip in the tyre sidewall it won't.
the alternative is to run higher pressure to avoid pinch flats and carry a few spare tubes & patch kit I guess.
Posted : 04/03/2018 3:49 pm
 JoB
get some tyres that you don't need a vice to get off the rim (i'd do that anyway, even if i was just doing short rides from home, no-one needs that risk), run tubeless, take some spare tubes
Posted : 04/03/2018 4:33 pm
 kerv
I ran Sammy Slicks last year, tubeless in the front and a tube in the back (cannot get the back rim to seal). I had zero punctures in the front and packed it in after the fourth punctured tube in the back! Definitely go tubeless.
Posted : 04/03/2018 4:47 pm
There is some panic mongering in here, it's just gravel not porcupines hiding in pointy rocks.  Being able to actually steer and decsend on a CX will make the biggest difference to if you get a load of punctures.  I rode the first one on tubes and have ridden at Keilder a reasonable amount with no punctures, even when loaded up with bikepacking kit.
Stick a 40mm upfront atleast if you can mind.
Posted : 04/03/2018 5:21 pm
 sb88
Cheers... Yeah I suppose the obvious answer is to get some tubeless tyres that I'm sure I can remove by conventional means if necessary! Maybe 35mm rear, 37 ish front...
Posted : 04/03/2018 11:47 pm
 muzz
Kerv, what psi were you running and were they 32mm?
Also, what's the rockiest the route gets? Thanks
Posted : 05/03/2018 9:12 am
