Tubeless, again, so...
[Closed] Tubeless, again, sorry,
[#4597356]
OEM Schwalbe RR, non UST, will not stop leaking through sidewalls, I'm using Stans sealant. Should I persevere?
Posted : 26/11/2012 9:50 pm
Yes it took me a few days, then they were good.
Posted : 26/11/2012 9:57 pm
Mine seemed to leak a tiny amount till after the 2nd ride. Not topped up since.
Posted : 26/11/2012 9:58 pm
tubeless ready?
IME they're just a bit too fragile. You may get them to stay up, but sealing after a puncture is 'troublesome'
Given up on them personally for proper UST Conti X-King.
Posted : 26/11/2012 10:05 pm
No, not tubeless ready, got one to stay tight. Think I'll give 'em a bit longer. Thanks for replies.
Posted : 27/11/2012 12:46 am
Have you ridden on them? This helps the sealing process. I thought Non Evo RR was a bit too fragile for tubeless. Fitted some Conti X King Racesport and they were a nightmare tubeless even after scrubbing the inside with soapy water and cleaning with meths. They were still dropping air pressure after a couple of months use. Since replaced with Conti Rubber Queen 😀 a superb tyre
Posted : 27/11/2012 2:25 pm
you mean these: http://www.on-one.co.uk/i/q/TYSCRRONEVO-26-225-BLK-TNA/schwalbe_rocket_ron_evo_folding_tyre___26_inch___225___black___triple_nano
They go fine tubeless on Crests but do take a couple of goes for the sidewalls to seal. Once you're done they stick.
They are very light and fast but, as above, a little flimsy in the sidewall, as the OO page says. You should be OK if not running them somewhere rocky.
Posted : 27/11/2012 2:55 pm
The only Schwalbes I've had satisfactory results from tubeless were Snakeskins, all the rest punctured if you gave them a sharp look. they sealed fine though.
Posted : 27/11/2012 3:42 pm
