Tube for bleeding H...
[Closed] Tube for bleeding Hopes
[#377121]
Does anyone know what diameter tube fits on the bleed screw to bleed Hopes? I ask as I'm trying to get some from ebay (no LBS)and the last lot I got just falls off.
Posted : 10/03/2009 11:46 am
dunno but its a load bigger than the stuff you need for shimano brakes, I've just got some tubeing from an aquarium shop for the shimano's - cheap as chips..
Posted : 10/03/2009 11:50 am
or pop into b and q, they sell it off the roll.
Posted : 10/03/2009 11:52 am
i just borrowed some from the chem store. So sorrry dunno.
Posted : 10/03/2009 11:53 am
oooh Lummox, what section does it come under?
(in case the aquarium stuff doens't pan out)
Posted : 10/03/2009 11:59 am
I used an Hayes bleed kit hose - they fit a treat - then drilled out a hole in an old vitamin pot with a soft flip cap on it, tied some string around the top so I can hang it from the bottom of the caliper and hey presto. Sorry dont know the diam though!
Posted : 10/03/2009 12:18 pm
it's in the rope/ chain / string department, if you find that you should find the tubing there on a drum with a useless device to trim it to size.
Posted : 11/03/2009 1:04 am
Windscreen washer tubing works well
Posted : 11/03/2009 1:05 am
Also silicone fuel tubing from a model shop if you have one nearby, also useful for pressure bleeding with a syringe as it's flexible enough to allow hand movement without popping off and squirting fluid everywhere.
Posted : 11/03/2009 8:47 am
Depends which brakes you have, the bleed nipple on the new tech calipers is smaller than they used to use.
Posted : 11/03/2009 8:55 am
You don't really need tubing if you're stuck
Just make sure you remove the wheel & pads before you start & give everything a good clean when finished [I do that anyway]
Posted : 11/03/2009 9:09 am
