Truvativ X9 and SRA...
[Closed] Truvativ X9 and SRAM DUB compatibility
[#11213962]
Hi. I just picked up some Truvativ X9 cran arms which have the SRAM direct mount chainring fitting and a spindle that has 'BB30 and PF30' on it. I've tried to install it into an SRAM DUB threaded BB but can't get the spindle into the bearings, even with a bit of 'encouragement'. IS there a compatibility issue here? I researched this before I picked them up and it looked like the X9 spindle would be compatible with the DUB BB so I'm scratching my head...
Posted : 27/05/2020 3:33 pm
Yes, BB30 is 30mm, Dub is 29.9-something. You need Dub cranks for Dub BBs.
Posted : 27/05/2020 3:35 pm
That's confusing and a bit annoying. There's lots of spiel in the DUB advertising about the way it's universally compatible....
Posted : 27/05/2020 3:54 pm
What they mean by compatible is any dub crank will fit with any dub bb I believe. So you don’t end up with different cranks for different frame standards - I.e bsa screw in / bb30 / pf30. You can use the same cranks for all of them but either the correct dub bb for the frame.
Posted : 27/05/2020 4:37 pm
Can the bearings be replaced on the DUB with ones that have a slightly larger internal diameter in order to accomodate the BB30 spindle?
Posted : 27/05/2020 5:29 pm
