I need to find a solution that will allow a road bike to store flat against the ceiling of a garage. ( this is the ONLY option )
Any sort of hydraulic or cable system available?
Saw that one already. The ceiling is about 11 foot high so not Ideal but workable.
I don’t need one of those, but I’d like one, just because.
Sell it and mtfu?
11 foot ceiling? You need a MEWP just to get it up there. What needs 11 foot of clearance underneath it?
Lots of pulleys and cord comes to mind.
why do you need to store it flat if its 11 foot high?
Would something like this not be sufficient? https://www.amazon.co.uk/dp/B00GXZHLLW/ref=asc_df_B00GXZHLLW57054981/?tag=googshopuk-21&creative=22110&creativeASIN=B00GXZHLLW&linkCode=df0&hvadid=309841504011&hvpos=1o1&hvnetw=g&hvrand=2180350453061709169&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006567&hvtargid=pla-557168903925&th=1&psc=1
Not difficult to set up a tray with 4 pulleys on the ceiling and ropes to each corner all leading to a single counterweight against a wall. Easy to fabricate in a day.
Two hooks for the wheels to hang it upside down then a pulley attached to the top tube to swing it up horizontal.
Could you get 3 of those plastic coated .? Shaped screw in hooks
screw 2 In so that you can hang bike upside down off wheels, then screw 3rd in {or a pulley} so that when you lift bike up parallel to roof you could catch top tube on 3rd hook
I can’t be bothered to make something. I want to buy a system that will work every time without issue.
And it absolutely has to be stored flat
Dig out the floor in a bike shape.
Buy a https://www.monstershop.co.uk/clothing-airer-ceiling-pulleys
Velcro strap/clamp/bungee the bike onto that and Robert is a sibling of yr mother.
If you want to spend double then this:
