Travel adjustable d...
[Closed] Travel adjustable droppers
[#12065165]
My giant trance has a too long seat tube for me to use a 175mm dropper, but only by like 5mm.
What droppers are internally travel limitable except the one-up post?
Posted : 07/10/2021 7:19 pm
I think BikeYoke are adjustable but they also cost a million dollars.
Posted : 07/10/2021 7:40 pm
Not all droppers are equal length from collar to clamp (stack) can vary.
For example, 180mm OneUp has a stack of 213mm while a 170mm Brand X is actually taller at 225mm.
Posted : 07/10/2021 7:59 pm
You can also make room by running shorter cranks or a lower profile saddle.
Posted : 07/10/2021 8:08 pm
This.  I’d be measuring everything (stack, insertion, etc) carefully before ordering.
I’ve been very happy with my One-Up but a travel adjustable alternative I’d consider is https://www.pnwcomponents.com/products/loam-dropper-post
Posted : 07/10/2021 8:11 pm
As above.
Posted : 07/10/2021 9:54 pm
Oddly I've been looking at this for similar reasons.
Although it doesn't Google too well I reckon KS Levs are. Their 65mm travel seems to be a 100mm-ish with a 'P3125-36' spacer:
And this bit seems to be the travel reducer for 125->100 Lev Ci.
http://www.linksports.com.au/kss-sp-p3125-25
And this has a ghetto reduction:
http://www.peterverdone.com/ks-lev-rebuild-and-travel-adjustment/
All looks a bit fiddly, but possible.
Posted : 07/10/2021 10:56 pm
Out of curiosity, what's wrong with the oneup? I've been using thier 180 post spaced down to 170 for a few years now without issues. Cheap to service too !
Posted : 07/10/2021 11:03 pm
If it helps I have a 170mm PNW Loam which I no longer require. 31.6mm diameter. Make me an offer if you are interested. There is a matching lever for SRAM Matchmaker that I also ordered with it
Posted : 07/10/2021 11:12 pm
This.
Also, you could bodge it by getting an old gear cable inner and clamping it to the saddle rails and seatpost clamp to limit the seatpost extension.
Posted : 08/10/2021 12:36 am
Isn't the PNW post the same as the Brand-X AScend? I know there are different versions of the Brand X, but I ran two Ascends for a couple of years with zero problems. You can adjust the travel with a bit of margarine tub plastic cut to the correct size and shape.
That said: I'm currently on a Oneup on one bike (faultless after an early issue with return speed that turned out to be not enough grease - Oneup includes a little pillow of the stuff along with keys which fixed the issue) and a Specialized Command Post which is amazing by nut-beltingly terrifying when it comes to return speed. I'm struggling to justify replacing it with a longer Oneup at the moment...
I don’t think you can beat the Oneup for low stack height - plus then the ability to adjust it down. Sounds like you could get the 180 with the option to space it to 170 or 160mm if required.
The newest brand x posts can’t be spaced down with plastic spacers btw - the old ones could be (they took the same plastic spacers as the V1 Oneup post). I don’t think they’re the same as the v2 Oneup which spaces down with different length brass guide keys.
I’ve got a 180 and 210 Oneup post. I had to limit the travel on the 210 to 200 to fit it in my frame with the correct saddle height at full extension.
Posted : 08/10/2021 10:28 am
I've been looking at this too and I reckon if I replace my Fox/Marzocchi Transfer with a One-up, I can go from 125mm drop to 160m, possibly 170mm drop with the One-up (by using their 180 and shimming it down a bit)! Thats pretty impressive.
Posted : 08/10/2021 10:57 am
9point8 post is internally adjustable
Posted : 08/10/2021 11:07 am
