Road vs MTB hydros
[Closed] Road vs MTB hydros
[#12065307]
Hi,
Are there any compatibility issues between road and MTB hydraulic brakes?
I have a bit of a monstercross thing going on using tiagra levers and M615 levers and I just can't seem to get them playing nicely together. There just seems to be a lack of power.
Posted : 07/10/2021 9:48 pm
Piston size on 2 pot callipers is the same, so should play fine.
I’ve got 2 bikes with GRX STIs on 2 different old versions of XTR callipers and they’re grand - same as full GRX on another bike.
Posted : 07/10/2021 10:55 pm
Thought was going to ask if more of a pain to bleed...yes until get hang of it
Running Deore 4 pot with 105 shifters and very happy
The only compatability issue aware of is shimano has two types of hose...around page 30 in this doc (pdf download) is a huge chart that explains all if you know your part numbers
https://www.google.com/url?sa=t&source=web&rct=j&url=https://productinfo.shimano.com/download/pdf/com/2.7/en&ved=2ahUKEwiay9WWv7nzAhVTxjgGHYadBZEQFnoECCcQAQ&usg=AOvVaw2DZI8VSB9PnmejV7VN-GIb
Posted : 08/10/2021 1:57 am
Thanks,
It must be something I'm doing wrong.
I'm going to replace the fluid, replace the pads and start again I think. Stick with shimano pads and see how it goes.
The calipers were great when used with the mtb levers.
Posted : 08/10/2021 8:01 am
