TranceX with 140mm ...
[Closed] TranceX with 140mm forks
I've got a 09 Giant Trancex frame that I built up with my own bits.
I currently have it set up with Fox Float R forks set at 120mm with quite a few spacers under the stem.
I've heard of quite a few people changing the forks to 140mm travel, mainly Revelations and Talas forks it seems. How well does it work?
I could take the 20mm spacer out of my forks and turn them into 140mm travel floats, I could then take some spacers out from under the stem to compensate. Will it make much difference to the way it will handle rocky descent? I mainly ride at Coed Y Brenin and the other welsh trail centres and sometimes feel I could do with slightly more travel on the front, the rear is great and in a way out performs the fork.
Any thoughts?
Posted : 12/04/2010 12:06 pm
i have a trance (not x) with 120mm
so trance with an x should handle 140 about the same - probably.
Ok thanks.
Ye I've heard of a lot of people upping the travel of the forks on the older trance too.
Posted : 12/04/2010 3:05 pm
Just spent all weekend on mine with 140mm Fox talas - the bike is now FANTASTIC rather than good but nervy.
!40 on the downs and flats, 120 on climbs ftw
Posted : 12/04/2010 3:06 pm
My 07 Trance rides far better 130mm Revs on it.....
Posted : 12/04/2010 3:08 pm
I've also got a Trance (not X) with 120mm forks, plus a Reign (not X) with 160mm forks.
Both were greatly improved by an extra 20mm over the travel supplied.
Give it a go, I'm sure it'll be great.
Posted : 12/04/2010 3:09 pm
Oh, and do try it with the stem as low as it'll go (removing conical spacer if it has one). My Trance handles much better that way.
Posted : 12/04/2010 3:10 pm
Mine doesn't have that conical spacer but I could remove about 20mm in spacers to lower the stem.
Does anyone run it with 140mm floats?
Posted : 12/04/2010 3:16 pm
sorry to jump in here - has anyone tried a coil shock on the Trance X?
Posted : 12/04/2010 3:33 pm
why would you?
Posted : 12/04/2010 3:34 pm
i think that the i2i is far to short for a coil shock to be honest - surely the linear nature of the coil would be all wrong?
Posted : 12/04/2010 3:35 pm
No reason why not, would need to be something like the old Vanilla R to fit though.
Posted : 12/04/2010 3:38 pm
I find the FoxRP23 on mine performs really well.
Posted : 12/04/2010 3:45 pm
was just wondering - fair dos
Posted : 12/04/2010 3:46 pm
Sure I've seen a coil shock on one on MTBR in the US. Not sure why though tbh..
Posted : 12/04/2010 4:17 pm
If you're unhappy with your air shock, getting it PUSHed might give you the improvement you are looking for.
I had the Float R on my Trance done by TF Tuned and it now rides much better. And more coil-like too, I'd say.
Posted : 12/04/2010 4:20 pm
Has anyone tried the TranceX with a 140mm Fox Float fork?
Posted : 13/04/2010 9:34 am
