Trailside quick lin...
Trailside quick link tool
Are tools like this worth buying or are they just a toy that's going to let me down?
https://ebay.us/m/yYA4PV
More for removal of chain quick links rather than as a tyre lever. I snapped a Granite Talon lever yesterday, looking at trail toolkit alternatives (I've got good pliers in the home kit).
Posted : 26/02/2026 9:25 am
You can use a shoelace or paracord apparently. There are a few videos around on how to do it.
Posted : 26/02/2026 9:49 am
I have this one, which I got for around 99p in an AliExpress flash sale when I was buying something else.
https://www.ebay.co.uk/itm/324036112101
The exact one you're looking at can be found for around is under £2 on AliEx too.
Posted : 26/02/2026 9:52 am
I've watched a mate do this successfully but never managed it myself although he made it look easy,  been carrying tyre levers with quick link tool but haven't actually tried using them yet so no idea if they're going to be any use
Posted : 26/02/2026 10:13 am
i carry a small gerber multi with needle nose pliers. They will pop a chain link along with lots of other handy jobs
Posted : 26/02/2026 10:46 am
I have used the Granite Tyre levers with quick link tool.  Works well, the leverage is handy as they can be a bastard.
Posted : 26/02/2026 11:12 am
Keando reacted
Posted by: BillOddie
So did the OP.  He’s the second who’ve reported them breaking, I’m worrying mine may let me down at a vital moment now 🙁
Posted : 26/02/2026 11:26 am
Keando reacted
Why not just use the inverted v/big chainring technique and skip the need for a tool? Quicklinks slack off with a few miles as well so little force is needed...
Posted : 26/02/2026 11:52 am
They work just fine, but I would recommend getting one that has some padding on the handles...
The raw metal handles are not at all ergonomic and wreck your hands if things are a wee bit tight/stiff. The raw handles can also be quite slippery when wet etc
Posted : 26/02/2026 11:58 am
I have one and have only used it once (on a mates bike), it worked ok, doubles as a tyre lever (though I've never used it as such) and stores a spare link. Not much to report really.
Posted : 26/02/2026 12:07 pm
I have a piece of old gear cable with ferrules criped on each end to stop it fraying.
Posted : 26/02/2026 12:10 pm
They work fine as chain link pliers. As tyre levers, not so much.
Posted : 26/02/2026 12:24 pm
Ah fair enough!  Can't remember the last time I used tyre levers out on the trail though.  That's me jinxed...
Posted : 26/02/2026 2:22 pm
Ah fair enough!  Can't remember the last time I used tyre levers out on the trail though and I do have either Pedros or Topeak Shuttle levers in my pack as well on "big" rides when I take a tube.  Punctures either seal themselves or just need a anchovy 99% of the time.   That's me jinxed...
Posted : 26/02/2026 2:24 pm
I went for the Topeak mini PT30 multi tool.  It’s got a quick link remover, storage for replacement quick link, plus tubeless plug tools so removes the need for other clutter.
Posted : 26/02/2026 4:57 pm
short length of coat-hanger wire here
Posted : 26/02/2026 5:06 pm
I've got the wolf tooth tool that those ZTTO ones have shamelessly copied.
Small, easy to stash in a tool roll, very handy way to break and fix a chain as well as store quick links.
Posted : 26/02/2026 8:56 pm
Posted by: boblo
Can you tell us a bit more about this technique please.
or You tube perhaps ?
Posted : 26/02/2026 9:08 pm
Here you go. He makes it look harder than it is by randomly battering the link tho... https://youtube.com/shorts/wAYtyczXGE0?si=RNQDNJ0RL1HRKJni
Posted : 26/02/2026 9:34 pm
Nice to have a DIY bodge in the back pocket, but I wouldn't want that as my default for the same reason I, for example, prefer using fabricated tensioners on a tent guy line rather than tying a hitch - I don't want to be doing that in the cold and dark, with numb fingers, in the rain. Sometimes the correct tool is just the way to go.
Posted : 27/02/2026 8:29 am
Ended up ordering one of the cheap master link tools from the original post, plus a set of steel cored levers. I tend to steer clear of multi tools, don't like having all my eggs in one basket.
Posted : 27/02/2026 8:34 am
