Trailer vs Panniers...
[Closed] Trailer vs Panniers for a road-based cycle tour
[url= http://www.physik.uni-regensburg.de/forschung/fabian/pages/mainframes/teaching/teaching_files/Physics%20Around%20Us_files/vol59no9p51_56.pdf ]Actual paper on bike stability[/url]
Its a bit mad and to be honest I haven't finished reading it. But the author built a bike with a contra rotating front wheel, just off the ground. The bike was apparently fine to ride thus undermining the gyo theory of bike stability. It was hard to ride no handed and if you pushed it unladden and let go it fell over
Posted : 12/11/2010 8:20 pm
Al - I ain't squire - Nothing I claimed is wrong. Read what I wrote.
You have got muddled up. Sometimes you need to step back and ponder
Wind resistance is directly proportional to frontal area and exponential to speed.
example I gave I very clearly said it was anecdotal, not replicable and that there would be other factors involved.
Posted : 12/11/2010 9:40 pm
..and that's how they were damaged....the eggs...you remember...the hard-boiled eggs I was telling you about...they were in a tupperware container, reputedly self-sealing, which fell open upon contact with the tarmacadam surface of the road....the B489...the Dawlish road... That shouldn't really happen to a self-sealing container, should it? What do you keep your hard-boiled eggs in? I think in future I shall lash them to the handlebars with adhesive tape...this should obviate a recurrence of the same problem...well I can't stop here all day...I'm on a cycling tour of North Cornwall. Must be off.
Posted : 12/11/2010 10:05 pm
The stability of my bike with panniers is only a problem when i'm trying to push it one handed through barriers at train stations etc. Seems much easier for it to fall over, i assume because the weight is right back behind the rear axle.
Also seems a bit unstable when out of the saddle with heavy panniers as they swing about a bit.
Its mostly fine though, and i'm sure you'll quickly adapt your riding style to either a trailer or panniers.
Posted : 12/11/2010 10:10 pm
skidartist - Member
But what about fruitcake? In a crash fruitcake would be much better protected on a trailer than in a pannier. If you kept your pump on the trailer its far less likely to get caught in your sock and your fruitcake wouldn't get damaged on one side.
This would only be applicable if undertaking a tour of North Cornwall with Clodagh Rodgers and Trotsky
Posted : 12/11/2010 10:15 pm
Coronworl...oh yes know Coronworl very well. Went to school there, mother and father live there, ah yes. Go many weekend parties and polo playing cards in blidge club. Belong many clubs in Coronworld.
Posted : 12/11/2010 10:18 pm
TJ I've read it, I've presented my argument and you've just said it's wrong.
I CBA discussing it if that's all you can be bothered to do.
Posted : 12/11/2010 10:26 pm
Pither, like 'Brotherhood' but with a 'P.I' instead of a 'B.R.O.'. And no 'hood'
September 2nd. Did not fall off outside Iddesley.
Posted : 12/11/2010 10:38 pm
Fell off in Tavistock.
What a stroke of luck. My Crunchie was totally intact. I settled down to a quick intermeal snack...
Posted : 12/11/2010 10:47 pm
Al - its late,l I have been drinking beer, according to the others I may have lost my fruitcake.
i am really unclear on what you think I have got wrong. try to expalin what you think I have wrong \and I'll pick it up tomorrow -0 or realise that its splitting hairs or counting angels or misunderstandings and forget about it.
Posted : 12/11/2010 10:56 pm
How could you miss?
He moved
Posted : 12/11/2010 11:02 pm
TJ
"and as its exponential (square IIRC ) its not 30%
but more like 70%."
that bit. no way can panniers add 70% more drag.
Posted : 12/11/2010 11:30 pm
 ojom
does touring really reduce you to 3pages of physics?
please say no as i have just turned 31 and have decided to start, the beard is ready.
Posted : 12/11/2010 11:43 pm
thebikechain - Member
Only if you use a trailer
Posted : 12/11/2010 11:45 pm
 ojom
I will not be using a trailer then.
Surely it should be fun and not a worry over frontal area and castor!!
Posted : 12/11/2010 11:47 pm
No your born with the physics. If you haven't got it now you won't
It doesn't matter what the question is, a trailer isn't the answer.
Posted : 12/11/2010 11:49 pm
Al - at no point did I say that.
You claimed that - I did not. I siad that with the bulky front panniers on out terminal velocity of the Glencoe road was around 35mph when on [i]similar[/i] roads without panniers we reached 45+.
This was an observation that I stated was anecdotal.
Drag is directly proportional to frontal area. I don't understand how you get the 70% figure from - it makes no sense.
Posted : 13/11/2010 9:20 am
Posted : 13/11/2010 10:27 am
TJ of course you didn't say that. but it's not wrong.
your point is that the panniers created enough wind resistance to slow you down by 10mph or 30%.
as wind resistance increases with the square of speed that would require the wind resistance to have increased by the square of 30%. you calculate that by squaring 1.3, which gives you 1.69 which I rounded to 1.7, ie 70%.
if you don't understand this then fair enough but that doesn't make it wrong (and can a numeratd person back me us please).
Posted : 13/11/2010 10:42 am
Come on, dear. Wake up dear.
Mother!
Come on dear.
So, it was all a dream.
No dear, this is the dream, you're still in the cell.
Posted : 13/11/2010 10:56 am
nightmare more like!
Posted : 13/11/2010 11:28 am
Cynic-al is correct in that if the drag factor is the same then a 30% decrease in terminal speed means a 70% increase in area. Thats keeping the mass of both bikes the same....
Posted : 13/11/2010 11:36 am
NO! wind resistance, not just area.
Posted : 13/11/2010 11:49 am
Al - it is far more complex than that and you are getting confused anyway.
Wind resistance increases in proportion to frontal area. The squaring only take place a s you bring speed into it. which produces the drag
You are confusing concepts here and its led you into an error. drag coefficient ( wind resistance) and drag ( retarding force)
Posted : 13/11/2010 12:27 pm
ok by wind resistance I mean drag (ie force), coefficient of drag is different I know and I thought that would have been obvious, how could anyone confuse that with force?
if I am wrong them what is the explanation?
Posted : 13/11/2010 12:38 pm
The explanation is that the panniers increased the drag to the point that the bike reached a lower terminal velocity and that I could feel this.
My post above is somewhat garbled as well. and I have reached beyond my knowledge now.
All I know is I could really feel the increased wind resistance with a bulky set of front panniers. I don't know how much they added to the frontal area or the drag coefficient. Just that it was a lot, it was obvious and it slowed us right down
You brought the maths into it and what you have presented makes no logical sense to me. i think you are confusing concepts.
Posted : 13/11/2010 12:44 pm
ah, so you don't know what I am talking about and yet you are arguing I must be wrong.
a new low.
must stop wasting my time.
Posted : 13/11/2010 1:34 pm
Al - I have no idea of the point you are trying to make.
It makes no sense to me at all. I suspect you have concepts confused as what you are claiming disagrees with my understaning of teh situation -but you are unable to explain what you mean - so you get offensive again.
Nice.
Posted : 13/11/2010 1:43 pm
You tell me I am wrong - that something I have experienced cannot have happened.
You come in with some calculations that make no sense and that you are unable or unwilling to explain.
I don't understand where you get your numbers from. I don't think you understand the concepts hence your confusion
I don't understand your need to put me down all the time.
Posted : 13/11/2010 1:48 pm
If it helps at all (probably not, but IIRC TJ has trusted my science before) in general I agree with Al.
To sum up the point he's making and keeping it as simple as possible:
If your terminal velocity is 45mph without panniers and 35mph with, then using
drag force = A*Cd * v^2
rearrange:
A*Cd = drag force / (v^2)
At terminal velocity drag force must be the same for both since it counteracts the force of gravity (which is constant for a given gradient). Therefore A*Cd is inversely proportional to v^2 - ie at 45mph
A1*Cd1 = k / 2025
at 35mph
A2*Cd2 = k / 1225
Bunging those two equations together:
A2*Cd2 = A1*Cd1 * (2025/1225)
A2*Cd2 = A1*Cd1 * 1.65
(so 65% more drag rather than the 70% Al claimed, but we're in the same ballpark - I think he just approximated a bit earlier).
{for the physics pedants I should point out I've simplified slightly by removing the p/2 term from my first equations, but that's constant so makes no difference}
Posted : 13/11/2010 3:15 pm
I am not saying it didn't happen, I am expaining that there must have been other factors, as the 30% reduction in speed would have required a 70% increase in drag, therefore your experience can't be down to the panniers, and is a bit meaningless.
I can't make the calcs any simpler I don't think, in any event it would be obvious to anyone that understood.
You've gone from me being wrong and you being right to you not understanding but me still being wrong (like many times before...) - can you see that might be frustrating?
EDIT yes AR I rounded the difference to 30% when it is in fact 2/7.
2 people backing me up TJ, am I still wrong?
Posted : 13/11/2010 3:17 pm
Oh and for the record, I don't believe panniers have anywhere near a 70% increase in drag - not even front ones. I think that's the point TJ is making (so I kind of agree with him too), the trouble is, that means the 35/45mph figures are wrong. It's worth pointing out that front panniers will also have a hugely bigger influence on drag than back ones, given the back ones do sit in your wake.
Posted : 13/11/2010 3:24 pm
Aracer - drag force 65% more but how does that equate into increase in surface area?
Al -at no point did I claim what you say I did. Go back and read it.
I still think you are confusing things.
but more like 70%."
Edit - aracer - the panniers were huge - around 80-90 cm wide and 50 high sitting up high on the front of the bike
Posted : 13/11/2010 3:29 pm
fairy nuff - in which case you're proving that atypically large front panniers have a significant influence on drag - not that much more relevant in the context of this thread than skidartists stop/start around town experience (admittedly my kiddy seat/trailer data may not be much better 😉 )
Posted : 13/11/2010 3:42 pm
aracer. Could you please give a reference for your
formula please I'd like to see where such a simple formula for drag comes from. I obviously know [url= http://en.wikipedia.org/wiki/Stoke s'_law]Stokes law[/url] as a simple drag relationship in a Stokes flow (which I am of course aware this is not) and have calculated drag using triple deck theory before but have never seen such simple approximation of drag unless I'm forgetting something very simple.
I'm not trying to say it is not valid but I'd like to see the derivation from the Navier Stokes equations that is all for my own interest.
Posted : 13/11/2010 4:02 pm
indeed aracer - thats all I said. IMO IME a large set of front panniers made a significant difference
I really tried to make it clear that this was not good data. Why al had to make such a pedantic attack on me I don't know.
Posted : 13/11/2010 4:08 pm
Found something in Prandtl's Essentials of Fluid Mechanics - Herbert Oertel
Not pleased with that approximation!
Posted : 13/11/2010 4:33 pm
I was using the same sim[le drag formula as aracer, I have seen it in bycycle science amongst other places
For the record I didn't say TJ was right or wrong about the effect of panniers I just said that for 2 bikes of equal mass and the same drag coefficient. Sadly a tandem is a poor example as it will have so much more weight.
However Cynical for the case of to bikes free wheeling at terminal velocity one at 30mph the other 45 mph then the drag forces are equal. They both are in equilibrium. They both have the same force acting down the slope so they both have the same drag. The slower bike is less aerodynamic so travels slower for the same drag force. TJ was clearly understands this point
Posted : 13/11/2010 4:44 pm
I think there was some confusion and misunderstanding on both sides. trying to describe physics in imprecise words
Posted : 13/11/2010 4:57 pm
90cm wide? really?
the post you've quoted above is what aracer has explained.
it seems you're trying to say you have some relevant date and at the same time that there are so many caveats it's irrelevant. which is it?
Posted : 13/11/2010 5:22 pm
Al - why don't you read what I wrote. Why do you have to search out points to attack me on all the time?
"cynic-al - Member
it's an attractive idea that aerodynamics suffer with panniers but I doubt any of us can really state that authoritatively, or that it's significant. There are too many other factors."
[b]True[/b] but I do have [b]anecdotal[/b] evidence - a wide set of front panniers ( big rears as well)on the tandem our top speed down glencoe was 35 mph. On [b]similar[/b] roads without panniers we reach 45+easily mph.
[b]Lots of factors for sure[/b] but certainly the frontal area was greater and it [b]appeared to me[/b] that the aero drag built more quickly that without the panniers
That is clearly anecdotal and clearly full of caveats and I agree with you that it is multifactrial. Just a bit of info to teh debate.
Why you feel it necessary to attack me in such a way - its not as if I siad "I know best this is what happened"
Posted : 13/11/2010 5:30 pm
Did writing down the equations actually help then?
For TheBrick http://en.wikipedia.org/wiki/Drag_equation (as I said, I left off the p/2 constant) Too many years since I did FD properly, so no idea how that relates to Stokes.
Posted : 13/11/2010 5:34 pm
Page 3 / 4
