Touring riding posi...
[Closed] Touring riding position
So I was wondering what the consensus was regarding riding position.
I have decided it seems logical to build a tourer up based on riding position first and foremost.
This conclusion is based upon the fact that my brooks b17 really really does require a more up right position. Should have bought the saddle last I guess.
Posted : 17/11/2013 12:04 pm
The consensus is - go with what suits you best.
You need to get out and cover a good few miles and work out what's going to work for you. I ride a drop-barred tourer on the road and a flat-barred "tourer" for off-road. both work well in their environment, both have their pros and cons. I've never tried the "butterfly" bar set-up that is very popular in mainland Europe where, btw, there are all sorts of "Trekking" bikes that are used for a variety of on- and off-road touring.
How much touring, or other longs rides, have you already done? What have you learnt so far?
Posted : 17/11/2013 12:08 pm
My normal road bike position. The only thing I might change is a slightly smaller frop from saddle to top of bars (normally 8cm) to allow longer on the drops into a headwind on a loaded bike. B17 saddle was fine for me with a drop of 8cm. and a
Posted : 17/11/2013 12:12 pm
I guess mine works out a few cm shorter and higher at the front - stem swap and saddle adjustment sort that.
You can always change the saddle, sound like you are wanting to build a bike around it?
Posted : 17/11/2013 12:21 pm
Yeah. Its and 18" inbred frame at the moment and I feel a more upright position works wonders on the b17.
Posted : 17/11/2013 12:24 pm
This (and I'm not ignoring the context of a slight change - I'd tend to argue that my road bike is set up to be comfortable on a 100 mile ride).
OP - you already seem to have worked out that selecting riding position based on a saddle is backwards - is this thread an attempt to try and justify that? Personally I've always used Flite saddles for touring. You could always try and find a different saddle which works wonders with your normal riding position - not really sure why a more traditional saddle is required for touring.
Posted : 17/11/2013 12:32 pm
Flite Ti and Brooks B17 are surprisingly very similar in profile. I always swapped seamlessly between them.
Posted : 17/11/2013 4:59 pm
b17 is not really bad in a racier position. The bars really need to be above the saddle and not level. Just wanted to know what position most people spent the majority of their time in.
Posted : 17/11/2013 5:44 pm
 ton
my bars and saddle are level. also got a adjustable stem fitted so I can higher the bars if I feel the need to.
sat upright is the best for touring, so you can see things, which is the whole point of touring.
drop bars on a tourer is pointless imho.
Posted : 17/11/2013 5:58 pm
My tourer has a B17 and the bars are a decent bit lower than the saddle. Comfort isn't an issue - nor is my visibility.
Posted : 17/11/2013 6:11 pm
if my bars were level with the seat I would need about 9 inches of steerer out of the headset
Posted : 17/11/2013 6:22 pm
I used to use a b17on my time trial bike
B17 doesnt need a special position !
Posted : 17/11/2013 6:23 pm
