Totems - can you ru...
[Closed] Totems - can you run them with no preload washer?
can you run totems (2010) without any preload washers? Set 'em up and with the med spring and 1 preload washer they sit on 20% sag. If you take out the washer then they should get more sag right?
But can you run them with the spring directly under the top cap with no preload washer in between.
Manual is pretty useless ๐Ÿ™
Posted : 17/03/2010 5:25 pm
