Torque settings for...
[Closed] Torque settings for a boardman FS pro 2012
[#6296505]
Does anybody here work at Halfords or have any relationship with Boardman?
I'm trying to find out what the torque settings are for the pivot bolts and I can't find it anywhere?! Have rang a Halford's store and they don't know either - makes me wonder how they build the frame in the first place....
Shirley someone must know?
Posted : 26/06/2014 8:27 am
a whopping 20nm on the bolts and 5nm on the ones that go into the frame
Posted : 26/06/2014 8:44 am
andybrad - thanks.
Not that I doubt your reliability, can I ask how you found that out?
Posted : 26/06/2014 9:19 am
I've read some horror stories about over tightening bolts on the frame, so want to make absolutely sure before I do it.
Also I rang what I though was the Boardman's helpline (it was in fact Halfords). After checking with their mechanic he said that for 4mm allen keys = 4nm and 5mm = 8nm.
Again, this sounded like a bit of an estimate (which may well be fine), so wondered where you got the 20nm and 5nm from?
Posted : 26/06/2014 12:12 pm
it was something i found on the web (think bikeradar) some time ago.
Anythng that goes through the frame was 5nm the 20 was for the bolts through the shock. tbh i did mine to 10nm and it never had an issue.
Posted : 30/06/2014 1:50 pm
Thanks Andy. I just went sensible middle of the road in the end (and cross referenced against aluminium frames with a similar geometry who sensibly PRINT it on the frame!)
Posted : 30/06/2014 2:38 pm
