Torque caps on RS f...
[Closed] Torque caps on RS forks
[#9866893]
I have some 2017 Yari forks and DT swiss hubs, the forks are designed to use torque caps in the dropouts which the DT swiss hub has, will a hope hub be okay in there without these caps?
Sorry bit of a silly question
Posted : 28/02/2018 10:57 am
Will be fine, just makes fitting the wheel a bit slower.
Posted : 28/02/2018 11:03 am
Yes it is absolutely fine but Hope do torque caps for their hubs and it makes it easier to poke the axle in (and gives you the benefit of awesome stiffness etc)
Posted : 28/02/2018 11:06 am
cool, thanks 🙂
Posted : 28/02/2018 11:07 am
Hope hubs are fine and a minor PITA, as above, although you can get 15mm Torque Cap adaptors from Hope.
Edit...too slow
Posted : 28/02/2018 11:08 am
Really?  that's cool, I will have a look for some of those.  Many thanks.
Posted : 28/02/2018 11:10 am
Hope adapters well worth the money. Makes getting the front wheel back in much easier.
Posted : 28/02/2018 11:14 am
HUB485 will do 100mm and boost hubs, HUB486 will do 100mm hubs for boost forks
http://www.hopetech.com/industry-non-standards/
Posted : 28/02/2018 11:49 am
I have the same fork and bought torque end caps for my Hope Pro 4 hubs. The make fitting easier as everything is lined up properly.
£17.50 from CRC.
Ignore the bit in the description that says they are for 15x110 boost hubs only. They are for non-boost, 100mm hubs as well.
Posted : 28/02/2018 12:17 pm
