Looks like top to me.
Can't really tell from that pic. It's certainly Top SWING (ie the moving part of the mech is ABOVE the clamping band).
Easiest way to tell is to pull the cable clamp bit up or down and see which of those ways makes the mech move - if you pull the cable clamp DOWN then it's bottom pull, vice versa for Top Pull.
top
Jeez those pictures are rubbish - you need to stand back a foot or so.
The mech should have the model number on it. You can then download the fitting instructions from the shimano website.
that might be the worst "better" picture i've ever seen 😆
Looks like top pull only to me.
Haha
They arent my pictures by the way.
Going from an unclear picture of the right side of the mech to an equally unclear picture of the wrong side of the mech really didn't help. 😯
.FWIW, I reckon top pull too.
Fitted one of those this afternoon. Top pull only, and specific clamp sizing, no shimming. Easy mech to set up though, if it fits.
The style in your pic is conventional (or bottom swing), David's is top swing.
Definitely Top (if you want it to replace a bottom pull it can be converted to bottom pull, just swap your old bottom pull quadrant & pivot pin which is longer & unscrews)
