To polish a painted...
[Closed] To polish a painted frame?
 Si
How easy is it to remove paint and get a polished finished to an all ready panted frame. Can it be done to steel aswell as alu.
Is it easily done at home or more of a send it away business and anyone got any experience on douing this. Once done I assume best then to put on a clear lacaquer coat rather than leave completely raw.
What sort of local business would do this work??
Posted : 07/10/2010 8:38 am
I read some guys were doing this to their deep Vs on the fixed gear forum. Patience, wet & dry glasspaper (sandpaper to your man on the street) and progression through the coarseness grades. When you start getting into the really high number grades it just needs finishing with a buffer.
Does require a fair bit of elbow grease and commitment!
Sandblasting may be an option as this should get into the nooks and crannies that glasspaper may not.
Posted : 07/10/2010 8:46 am
There was a phase of people on SDH nitromorsing their frames a while back, just search for 'nitromors' lots of threads about it!
[url] http://www.southerndownhill.com/forum/index.php?action=search2 [/url]
Posted : 07/10/2010 8:47 am
I have heard lacquering over steel doesn't work too well.
I'd be bead blasting & power buffering unless you have a huge time:money ratio.
Posted : 07/10/2010 8:48 am
Nitromors will do the job but is messy and nasty.
Sandblasting is easiest - yellow pages should help
Bear in mind that steel will need lacquering to avoid rust and depending on the type of alumninium, it may tarnish (go dull) if not lacquered.
I wouldn't bother myself (having done it in the past).
Posted : 07/10/2010 8:49 am
