TMARS dropper won&#...
[Closed] TMARS dropper won't stay up
[#8136060]
I changed the outer and cable on my dropper but it now drops down with a clunking. It's as though the cable isn't being released properly but it does it with the lever removed so the cable is slack.
Any ideas?
THanks
Posted : 31/10/2016 4:31 am
It is sensitive to cable adjustment but if you are getting it fully slack then maybe the pin is sticking. Open it up, clean it and grease it. Doesn't take long.
Posted : 31/10/2016 8:15 am
I think they're also sensitive to the size of the ferrule on the end of the cable, try filing it down a bit
Posted : 31/10/2016 8:53 am
Seems to be ****ing sensitive to everything including atmospheric pressure!
@connect - length or width? I replaced tha cable and used D. It's visibly larger than the cable head I removed but doesn't seem to be fouling anything.
@Nick - it's all opened up and seems to be running fine. It was packed full with thick grease. Is this normal / correct?
Posted : 31/10/2016 10:26 am
Probably a bit of both length and diameter. Unless yours is a different version, mine's an older one that the cable enters from the bottom of the junction box
But yeah, it seems you do have to be prepared to do a bit of fettling to get them to work properly
Posted : 31/10/2016 10:57 am
 tomd
I had one of these POS for a bit. Thick grease seemed to stop it moving at all, it needed to be dry & clean inside to work at all.
Posted : 31/10/2016 11:14 am
