After some ti forks for my ti 29er frame, need to be 15mm maxle and ideally tapered steerer ? What are my choices?
Thanks
Those Stooge ones.
Now they were nice.
Wittson Cycles Nulla look very nice.
Clee cycles have some Torus ones.
yeah I've seen the torus but they are not 15mm maxle
Do you really need a thru axle on a rigid fork?
Black sheep cycles.
what axle to crown and fork offset do you need, or more simply, what frame are running? I produce a couple of ti forks, one is a regular unicrown with tapered steerer and 15mm thru-axle, the other is a little more fancy and still at prototype stage. The unicrown is £300 including postage and maxle. drop me a line - andrewj.stevenson@hotmail.co.uk - if you'd like some photos and more info. Thanks, Andy@StoogeCycles
if you have patience and finance the black sheep forks are good
Torus forks are very good and stiff as hell with 36mm tubing. even running with a QR lateral twist is not an issue. Now use black sheep unicrown forks with a 15mm axle, great forks, be honest when you tell james your weight as he varies the thickness of the tubes to the rider weight and how they ride, so if you are biffer on a light fork it will flex like buggery rather than be a lovely supple ride or conversely it will be overly stiff.
Thanks everyone
everyone - MemberDo you really need a thru axle on a rigid fork?
If you're using discs, I'd say so.
I had a QR come out under heavy braking on a rigid fork, it was not ideal.
yes disk brakes and 15mm axle is what I need
