Tiny Cut in ust tyr...
[Closed] Tiny Cut in ust tyre (2mm)
[#4274594]
As per title, cut tyre on rocks at whinlatter yesterday, stans had gone off so cleaned and re filled when I got home but still leaking this morning, is it scrap or will patching work ? I don't want to run tubes due to running 30psi at the rear and got a pinch flat after about 20mins . As you can guess yesterday was more of a walk than a ride .
Posted : 19/08/2012 7:57 am
A sticky worm will probably fix that. Failing that, a car tyre repair plug for bigger cuts. Is it in the tread or the sidewall? Tread cuts will normally repair easier than sidewall damage.
Posted : 19/08/2012 7:59 am
You could try one of those tubeless patch kits you can get. It's a plug that goes through the tyre- similar to how it's done on car tyres. Clarkes and others make them I think, probably crc stock them?
Just give it a clean out and stick a patch on the inside, it'll be fine
Posted : 19/08/2012 8:02 am
2mm just a normal tube repair patch inside should suffice. Unlike the the half inch slate slash I got in mine yesterday 🙁 2 months light use and useless for tubeless, it can be a tiresome old business ust.
Posted : 19/08/2012 8:08 am
Cheers guys , the cuts tiny and in the centre of the tread so I'll buy a decent puncture repair kit and have a go at it .
Posted : 19/08/2012 8:09 am
 devs
Anchovy will fix that but I also suspect that if you have enough sealant in and aren't skimping, it'll just fix itself anyway. I've heard a wee dod of superglue works too but never used it on tyres myself.
Posted : 19/08/2012 8:14 am
Cut out a small patch of inner tube and stick it inside the tyre with some contact adhesive.
Posted : 19/08/2012 8:15 am
At a glance that title reads very wrong...
Posted : 19/08/2012 8:25 am
