I am looking to buy some Ti bolts and spacers for my disc brake calipers. Where from and do they normally supply with the correct spacers as the ones I have looked at all seem to be bolts only?
Thanks
S'ok, found some.
eBay, usually from China/HK etc.
Careful, most come without loctite and will wiggle loose in 10 minutes. Get some yourself and apply before fitting (voice of experience here ๐ณ )
Yeah got the kit from Ebay.
Thanks for the advice, will do.
grease is sufficient in the hands of a competent mechanic.
www.tastynuts.com (Pro-Bolt) - I've ordered about ten lots of different bolts from here in recent months, always had excellent service and fastest possible postage. My latest order (late Sat night) arrived today - two 10mm M3 blue ano ti bolts for the rear mech hanger on my ti Ala Carte (also ordered two stainless just in case)... ๐ณ
Cheburashka - I did look there but couldnt see spacers - just the bolts.
Ah yes. There are [url= http://www.tastynuts.com/Products/1104000200050001 ]these[/url] with washers (2nd from bottom), but I can't find any with proper spacers on there.
Plenty of Ti washers though including some trick drilled ones (for whatever excuse you can find to used them):
[url= http://www.tastynuts.com/products/titanium_washers_drilled ]Click[/url]
