Thule ThruRide 565....
[Closed] Thule ThruRide 565...opinions
Anyone use these?
Just wondering whether they're good... I use ProRide 591 & 598 and Yakima HighSpeed, but think these might be better for longer distance drives.
Do they damage thru axles?
Posted : 24/10/2020 1:00 pm
I am a big fan; I've had them for years on different cars and they're absolutely rock solid. I'm always a little nervous of the normal ProRides as they rely on clamping the frames, and I always wonder how much stress they put a frame under - especially if you're leaning into a fun set of corners, say.
Although putting wheels in the boot is a bit of a dirty job, you can shove the wheel in a wheel bag if you must. Getting the bike on the roof is no harder than ProRides - you just have to watch for dropping the forks onto the roof - but the knack is to make sure the rear wheel strap is ready to take the rear wheel, and then slide it all up in one motion.
I have 4 now on my 5 series and all the bikes go up there - even the kids. I just know that the bikes will be properly solid when I'm driving along. Even at 3 figure speeds (in Germany, obviously).
They rarely appear 2nd hand on eBay, so you may need to bite the bullet and go new at ~£155.
Well recommended in my book.
Posted : 24/10/2020 1:58 pm
Bought one a couple of moths ago - seems to work well and is rock-solid.
Posted : 24/10/2020 2:15 pm
They do not damage thru-axles btw - in fact, they work really well - load is spread across the whole thru axle.
The 565 fits 15/20mm out of the box - and adjust to your hearts desire (based on how tight you want it).
Should also come with a 9mm QR adaptor which works really well should the need arise.
Posted : 24/10/2020 2:58 pm
Thanks folks. Might get a couple and sell some 591s....!
Posted : 24/10/2020 10:02 pm
