Thred gone in stem ...
[Closed] Thred gone in stem what can I do ( helicoil )
[#3114425]
My Thred in my sunline v one stem has gone as I've tightened the bolt too much. just wondering if it's worth geting it looked at rather than spend another £60-70. Any idea wat I can dovand a idea of costs
Posted : 04/09/2011 11:55 pm
thats a really bad idea. buy a new one.
Posted : 05/09/2011 12:01 am
A properly done helicoil in an aluminium base material will be stronger than the original thread. No reason why not if you can do it properly.
Posted : 05/09/2011 12:09 am
Most things can be helicoiled, A kit is £20 - 30 or getting one done by an engineer / bike shop will be a similar amount.
Is it worth it for a stem? I doubt it.
Posted : 05/09/2011 12:10 am
I drilled out a stripped stem thread and re tapped for the next size up bolt. I only really did it to try out a cheap set of tap and dies, so its had no real use, but appears fine.
Posted : 05/09/2011 12:27 am
Pretty sure I said this yesterday....
http://www.singletrackworld.com/forum/topic/help-please-threading-gone-in-sunline-stem
Maybe take a picture of the front of the stem with no face plate on so we can see how much meat there is to drill into.
Oh and buy yourself a torque key (about £13 set to 5nm)
Posted : 05/09/2011 12:54 am
You could get it helicoiled... Or, you could get a perfectly good new stem for much less than that. Pro, Gusset Staff, etc.
Posted : 05/09/2011 1:22 am
I did the same yesterday on my 4 mth old v1. I'd just serviced 3 sets of forks and was fitting the last stem.
Defo not overtightened, was just nipping up (as I had done on the previous 2) never known this to haapen before.
Posted : 05/09/2011 7:10 am
We'd normally charge a tenner to fit one helecoil, so worth shopping around and getting it done.
Posted : 05/09/2011 7:29 am
