This bleed block ok...
[Closed] This bleed block ok for Guide calipers? (Pic)
This is in my parts bin but is it ok for Guides?
Its [b]10mm[/b] in width.
Thanks guys!
Posted : 28/02/2017 8:04 pm
Unsure why it wouldn't be...I think (although, suspect I'm wrong) but the gap that the pads and rotor sits in is standard...so I'd say it should be fine.
Posted : 28/02/2017 9:19 pm
Cheers bud, good enough for me. ๐Ÿ™‚
Posted : 28/02/2017 10:20 pm
I use a 10mm Allen key so as long as it's 10mm it should be fine.
Posted : 28/02/2017 10:25 pm
I use some bits of card sellotaped together for a bleed block, same one worked on my elixir and guides.
Posted : 28/02/2017 10:29 pm
Cheers guys.
Inventive solutions too!
Posted : 28/02/2017 10:39 pm
That's going to cause issues I'd think.
It's intended for a 2-pot Elixir and may be thick enough but isn't really long enough.
What you really want is one of these and they aren't that expensive...
[url= http://www.bikegoo.co.uk/components-c8/disc-brake-spares-c11/avid-bleed-block-elixir-trail-guide-p58/s166?utm_source=google&utm_medium=cpc&utm_term=avid-bleed-block-elixir-trail-guide-a150140b&utm_campaign=product%2Blisting%2Bads&gclid=CJis5byZtNICFU0Q0wodS2MMkA ][/url]
Posted : 01/03/2017 1:57 am
Yes well the self fashioned card block went in narrow side for the 2 pot elixirs, and broadside for the 4 pot guides. The fact it fitted both was just a coincidence, but I would have just cut some new if it didn't.
Took the idea from http://www.epicbleedsolutions.com/products/accessories/bleed-block-kit/
Didnt fancy paying a fiver so I just used some old business cards laying around.
Posted : 01/03/2017 7:24 am
