thinking of going 1...
[Closed] thinking of going 1x10, any thoughts?
[#1668734]
i'm running 1x9 at the moment, and am pretty happy with it. Smacked the shifter and broke the housing (but still works), and need a new chain and re-mech,
so figured if i'm replacing these, may as well go 10 speed, and gain a 36 at the rear.
anyone used 1x10 yet? take it I have to get a 10 speed chainring, if so, anyone know where to get one?
sorry if it's already been done to death, did a quick search and nothing came up?
Posted : 03/06/2010 8:52 am
njee20 is your man for this one, but as far as I know, you can run the chainring you have, and mech too if its salvagable, but you will need the chain cassette and shifters.
Posted : 03/06/2010 9:04 am
mech's on it's last legs (is 9 years old) so i think i'll have to bite the bullet
would be good if i could keep the chainring, but perhaps a good idea to change all at once
anyone know when the shimano 10 speed will be available? and is it any better than SRAM's?
Posted : 03/06/2010 9:56 am
why not just go 1x9? i doubt you'll feel much difference. and youll be able to do it MUCH cheaper.
Posted : 03/06/2010 10:00 am
as i have to replace most of the parts anyway, and cost for STX doesn't look much different, i'm thinking why not?
Posted : 03/06/2010 10:02 am
read the op nicko
Posted : 03/06/2010 10:03 am
You'll just spend more time shifting gears
Posted : 03/06/2010 10:06 am
Aye, go for it. May as well.
Posted : 03/06/2010 10:10 am
Sit tight for a little while, if nothing else the price of XX cassettes and shifters is absolutely laughable, and mine seems to be wearing just as quickly as an XTR cassette.
Once SLX/X.7 are available I think it would make a lot of sense, you should be fine with your current chainring, the 11-36 cassette gives a really wide range, would go nicely with a 34/36 chainring I'd say.
According to the Madison website SLX 10 speed 11-36 cassettes and pairs of pods are due on the 19th July, so not too long to wait! RH only pods are due 26th July. Sensible prices too, £50 for the cassette, and £30 for the RH shifter, reckon that'll convince a lot of people to shift when stuff's worn out.
Posted : 03/06/2010 10:11 am
You may need to change your rear mech too depending on what you have at the moment. Older ones are only rated to a 34T so if you go to 36T you may have the top jockey catching the cassette.
Posted : 03/06/2010 10:21 am
