Thin waterproof soc...
[Closed] Thin waterproof socks
Getting to that time of year when wet feet becomes more of an issue so thinking of getting some waterproof socks. I already have some thick Sealskinz socks that are ok with my roomier winter boots but looking for some thinner weight socks so I can wear my normal shoes too. Still go for SS or do any other brands do a better thinner option? Will be wearing with Fox Flexair trousers and possibly with shorts on occasion so don’t want them cut too low...cheers
Posted : 01/11/2020 8:50 am
Bunch of the boys I ride with use the dexshell ones, they are apparently more like a regular sock.
Been meaning to order some for a while but haven’t got round to it yet!
Posted : 01/11/2020 8:54 am
I've got both dexshell and Sealskinz.... The dexshells are thinner but I find the sealskinz tend to keep your feet warmer for longer.
Posted : 01/11/2020 12:25 pm
Tuesday bump.
Ok, put it this way, what socks do you wear when it's shitty and wet outside?
Posted : 03/11/2020 12:30 pm
Ok, put it this way, what socks do you wear when it’s shitty and wet outside?
Merino wool, likely a Planet-X Thicky. They'll get wet but your feet should stay warm.
Posted : 03/11/2020 12:50 pm
Merino wool, likely a Planet-X Thicky. They’ll get wet but your feet should stay warm.
+1
Posted : 03/11/2020 12:53 pm
Dexshell or Woolie Boolies.
Posted : 03/11/2020 1:06 pm
 MSP
Wool socks get waterlogged, and the water transmits heat away from the body. Merino wool is hollow fibre so works slightly better to retain heat, but it isn't a good solution, it's the least worst of two bad solutions.
Merino wool is nice when your feet remain dry.
Posted : 03/11/2020 1:11 pm
I tend to use neoprene socks - you can get some quite thin ones - that way you're not bothered about them getting wet - when it gets properly cold I then go to winter boots. I've also just ordered some of those rubber swimming socks to try over normal socks...
Posted : 03/11/2020 2:17 pm
 Del
gore gortex socks.they won't stay waterproof for ever but last me a few years and then the old ones get demoted for cold damp days and the new ones wheeled out for proper biblical ones. wear whatever socks comfortably fit underneath.
Posted : 03/11/2020 4:51 pm
