these new 15mm hubs...
[Closed] these new 15mm hubs/bolt thru.....q
 ton
[#331401]
got a bike with a 15mm bolt thru with a fox fork.
i want to order some new ton proof wheels.
what should i ask for.
is it a 20mm hub with a reducer in??
Posted : 23/02/2009 12:02 pm
get a hope pro 2 20mm hub and a 15mm convertor
Posted : 23/02/2009 12:19 pm
Well it was designed with Shimano so I guess you can get Shimano hubs in 15mm flavour.
However, I would go with the Hope suggestion myself.
Posted : 23/02/2009 12:25 pm
you don't need a hope 20mm hub and reducer- the basic hub has different inserts depending on what axle flavour you use- just get a proII hub with the 15mm insert- won't cost any more than any other front hope proII hub.
It's your best bet, cos when you realise that you would rather use some other forks you don't need to sell the wheel.
Posted : 23/02/2009 12:29 pm
vinnyeh - Member
Care to elaborate? Have you ridden a pair?
Anyway, Pro 2 is the best option and future proofs them (apart from needing the relevant adaptors.
Posted : 23/02/2009 5:12 pm
Shimano do do SLX 15mm and XT 15mm hubs but both in centrelock only, and both about 50g heavier than a pro II (probably due to the cup/cone thing they have going on. Can't be converted to a 20mm though
Posted : 23/02/2009 5:15 pm
nickegg - Member
vinnyeh - Member
I'm on qr15 floats atm. They're fine for me-noticably stiffer than the qrs, at least to my perception- but firstly, Ton seems to, like many others, swap bikes and components with impunity - as you said, it's about change-proofing; secondly, I still would rate Pikes as a better bet for a man of Tons err qualities.
Posted : 23/02/2009 9:11 pm
 ton
i was thinking of swapping the fox float r for a set of pike air.
the fox's seem pretty tangy and flimsy compared to pikes.
only rode them once.
Posted : 23/02/2009 9:16 pm
