My SS chain is worn so that it occasionally bounces off the sprocket. I'm using a frame with a standard set of dropouts and a Powerplay chain tensioner (that had no instructions on how to tension it). How do I wind on more tension to the tension arm? Is it a case of using a cone spanner to hold the spanner flats at the rear of the tensioner while using an allen key to tighten an internal spring?
Posted : 05/04/2012 8:31 am
