Tell me about beari...
[Closed] Tell me about bearing removal/fitting tools
I'd like to get a bearing removal and fitting tool(s) to change wheel and frame bearings, but know nothing about them. Is what i want a bearing "drift" tool? Are there different sizes for each bearing? Will one tool do most bearings? eg
[url= http://www.amazon.co.uk/dp/B0031SQKUM/ref=asc_df_B0031SQKUM9300129?smid=A3P5ROKL5A1OLE&tag=googlecouk06-21&linkCode=asn&creative=22206&creativeASIN=B0031SQKUM ]this[/url]?
I made a threaded rod press which just about worked but then I used a proper headset press and decided I definitely "need" the tools! It's a lifestyle.
Posted : 20/08/2012 1:15 pm
a socket set is the ideal drift kit ! You get more sizes than on that link plus they can kill more than one bird if you catch my drift ( no pun intended )!!
Always worth keeping the old bearings as drifts for future too !!
Unless your running out of space in your wallet of coarse in which case buy a park tool one they are suitably overpriced on most things !!
Posted : 20/08/2012 1:24 pm
some/lots of bearings are blind - you can't get 'behind' them to tap/push them out.
you'll need something like this:
(a selection of expanding widgets, and a slide-hammer)
some people have some success using expanding bolts - i've never managed to get this to work.
Posted : 20/08/2012 1:36 pm
these guys make some
no experience of them though
http://www.rapidracerproducts.com
Posted : 20/08/2012 1:55 pm
The blind removal tool only removes them, so I'll need something else to press them in. I have a cyclus headset press which is e right kind of thing, does anyone know if you can get alternative size fittings for that?
Posted : 20/08/2012 5:01 pm
You get specific tools for specific bearing sizes. You can press bearings in in different ways too, they can be tapped in with a hammer and a drift, pressed in using a vice.
What frame and what hubs?
Posted : 20/08/2012 5:16 pm
I'll mostly use it for bbs which are 6805 bearings, hubs are superstar ones, and possibly Royce but I would hope they won't need replacing! Frame an intense spider.
Posted : 20/08/2012 6:12 pm
For various bearing replacment ideas have a look at the following videos
Keasae's you tube channel
http://www.youtube.com/user/KaeSae1/videos
Hopes vid for removing BB bearings
Various vids from Hope on how to service hubs etc
http://www.hopetech.com/page.aspx?itemID=SPG219
most of these vidoes use drifts/presses to remove and replace the bearings, for all but some of your frame bearings i would think this method would work for you too. I don't know your frame to know if you will need a blind puller to remove any of the bearings but am sure other will be able to advise.
Posted : 20/08/2012 6:50 pm
