How can I convert a Cannondale RZ120 3 2010 to use a set of tapered Rockshox forks...can anyone help me please?
thanks
buy a new headset ........
1.5" at the bottom
1 1/8" at the top
SIMPLES
okay.....
but as far as I can see it is an integrated headset with 1.5'' diameter bearings top and bottom ie. it does not have push fit bearing cups like a standard frame.
so....
my question is perhaps better defined as.....what headset/bearings/adapters, from where?
it does use cups but they are hiden in the head tube, hope and superstar do one to fit.
mttm - MemberHope will sell you a "Combi" headset - you can specify which top and bottom cups you require in a proper pick 'n mix stylee. They even do two taper reducer options for the bottom cup, an internal and an external. The external taper reducer helps with frame clearance on some forks.
swap your top cup for this one and leave the bottom one as is?
http://superstar.tibolts.co.uk/product_info.php?cPath=25&products_id=113
will work and not be seen
thanks that's useful info
cheers ๐
get a lefty :p
