Tapered headtubes?
[Closed] Tapered headtubes?
[#4695597]
Dumb questiontime!
Are they all the same length? Or do they come in a variety of lengths?
Posted : 30/12/2012 8:16 pm
yea dumb question..... different lenths
Posted : 30/12/2012 8:18 pm
Thats what I thought.
eBay seller full of cr@p then...
Posted : 30/12/2012 8:19 pm
Can anyone do me a favour and measure their tapered headtube length please?
Posted : 30/12/2012 8:38 pm
can you not just look at some websites? gaint, on-one etc. seem quite short, my Salsa is 120mm, thats a Large tho, other sizes are...er... other sizes.
Posted : 30/12/2012 8:43 pm
You also need to take the type of headset into account...some will have inset, external cup or a mix of those.
Posted : 30/12/2012 8:44 pm
Thats a dumber question than the first one, hang your head in shame!
Posted : 30/12/2012 8:46 pm
just ask him what bike the forks have come off. do some research to find out the ht length. then compare to yours..... but like d45yth says you need to take headset type into account
Posted : 30/12/2012 8:48 pm
What Duggie style said. What next? Measure our gear cable length?
Pedantry aside...all tapered head tubes are different in length depending on the model and size of bike. Are you after the internal sizes for headset compatibility?
Posted : 30/12/2012 8:51 pm
[shame]
Sorry.
Posted : 30/12/2012 8:53 pm
😀 What is it you're trying to do/buy/find out? If you say what that is, someone might be able to help you more.
Posted : 30/12/2012 8:57 pm
STATO
The head tube on my Wanga is also 120mm 😕
Posted : 30/12/2012 9:04 pm
Looking at a VERY cheap frame on eBay to fit some tapered talas forks with a 205mm steerer. Fitted my old trek fine but wanted to make sure that I'm not wasting money on something that will be useless.
Frame is a voodoo wanga. EBay seller has responded that HT is 120mm "industry standard" ( which, as you lot have said, apparently isn't as my spicy is 130mm)
So assuming I win it I can fit a zero stack headset and still have some spacer space left?
Posted : 30/12/2012 9:06 pm
you should be fine with a 205mm steerer
Posted : 30/12/2012 9:09 pm
Is it the 2011-12 wanga?
I've got one in front of me.
Without taking it out my steerer is approx 200mm and I've got 25mm of spacers and almost 10mm in the top section of the fsa acb headset edit (which is zero stack at the bottom end)
if nothing else the seller can use a tape measure correctly 😉
Posted : 30/12/2012 9:13 pm
Acidchucnks. Yeah 2011.
Very helpful. Thanks a lot!!
Posted : 30/12/2012 9:16 pm
you're welcome 🙂
btw, if its the ebay listing I found, there is no rrp for this frame as it can't be bought separately, only as a complete bike so the £399 quoted is BS.
Also I can only see pictures of the right side of the frame, the left could be scratched to fark
Posted : 30/12/2012 10:08 pm
