Tapered headtubes?
[Closed] Tapered headtubes?
Got a Yeti ASR 5 on order which has a tapered headtube. I was going to order a Rockshox Revelation U-turn to go with it but have found that version only comes with a straight steerer. My question is do the stiffness benefits come from
a) the headtube itself, in which case using a straight steerer with a reducer headset would give the same benefits
b) the tapered steerer on the fork, in which case the tapered headtube will have no benefit without a tapered fork to go with it.
I am tending to think that it is b) that flex in the front end is mainly in the steerer crown joint. Any views?
Posted : 26/01/2010 8:44 am
[i]Got a Yeti ASR 5 on order[/i]
Lucky git!
Pretty sure it's b) though.
Posted : 26/01/2010 8:54 am
a combination of the two,
big tubes give a bigger weld area so the join is stiffer, and big head tube allows a big downtube and the bigger tubes are inheerently stiffer anyway.
Same for the steerer.
Thats why DH frames normaly have 1.5" headtubes but run 1.125" steerers.
Posted : 26/01/2010 9:05 am
IIRC Brant has said it's the ability to run mahoosive down tubes that's the benefit.
Posted : 26/01/2010 9:12 am
2nd the headtube as being the biggest benefit. a tapered steerer will help, but not as much.
Posted : 26/01/2010 9:13 am
