Swapping forks betw...
[Closed] Swapping forks between traditional/integrated frames
[#1833411]
Does anyone know if there are external and integrated heasets which use the same crown race, to facilitate swapping forks from two bikes? I use Orbit XL2's on 3 of my bikes, which means if I am swapping between rigid and FS forks it is a matter of minutes - the crown races are already fitted. But I am looking at the new carbon frames from on-one, the new XC whippet looks nice - but they have internal headsets.
Maybe the Orbit Z uses the same race as the XL2's?
Posted : 26/07/2010 4:41 pm
Not sure about the FSA, but Hope might be worth a look and you could probably find out with a quiock phone call.
Come back and let us know if you do. I've been thinking of doing the same myself!
Posted : 26/07/2010 4:43 pm
hope all use the same crown race. Not sure if a hope crown race will work with FSA but have found they work pretty well with most cane creek headsets
Posted : 26/07/2010 5:00 pm
Why not simply change the race each time? Only takes a minute surely?
I would imagine anything that uses common bearings. I think all Hope and lots of Cane Creek use 41mm x 45 degrees by 36 degree ACB so they'll have common crown races.
Posted : 26/07/2010 5:02 pm
If you do it a lot (and are hamfisted like me) you end up chipping the fork crown and deforming the race.
Posted : 26/07/2010 5:13 pm
Hope do indeed use the same race (HS120) and even better it is split so can be taken off forks in seconds. The FSA is continuous and needs a good bit of chipping and swearing, especially when your nice Foxes loose small bits of paint. I might go for the expense of Hope (great BBs and hubs, so why not the headsets as well?). But I will see if I can get in touch with FSA to confirm before I splash out on all the cash and keep my XL2's.
Posted : 26/07/2010 5:41 pm
