Swapping forks
[Closed] Swapping forks
Will it cause any problems if I stick my Mazzi 55ATAs on my Epic for a weekend ride?
I don't know what the max travel on the Epic should be.
Posted : 04/05/2009 12:57 pm
Too much travel at full height so the handling will go to pot. You can drop them down to 125mm though, which should be fine, but you'll be carrying around a bit of excess weight. Find out teh axle to crown height of them, you might find they are still a bit too tall at 125mm andit messes up the handling. Either way its out of the warrnty range, but only just.
Posted : 04/05/2009 2:21 pm
In the end ICBA to swap the forks out on the Epic just for a weekend ride. But I may do it for the Trail Hunter I've got hanging around........
Posted : 04/05/2009 2:49 pm
