Swap my RT3 shock f...
[Closed] Swap my RT3 shock for ???
[#9360504]
I'm not impressed with the RT3 that has come on my NP mega now there's a cane creek inline for £125 on ebay I generally do cannock,pines and messing about in the countryside (and no not dogging-yet!!) Any others worth a shot ? I was impressed with the fox evol but not a Kashima RP23
Any advice from the STW massive ??
Posted : 02/06/2017 3:49 pm
might that be too good to be true ? (I've genuinely no idea, but CC shocks aren't exactly faultless are they ?)
Posted : 02/06/2017 5:47 pm
I'd avoid second hand Cane Creek IL's due to reliability.
Whats wrong with the RT3?
RT3's are fine once you get the right set up. Takes some patience and testing though. Make sure you run the right sag, rebound and volume spacers.
a suspension company can help with set up, getting it valved right for you etc if you are clueless.
Posted : 02/06/2017 6:10 pm
That might be it joefm I might perserve and see if I can get it ,the CC was rebuilt end of last year by TF which makes me wonder why it's as cheap as it is
Posted : 02/06/2017 6:17 pm
 poah
that does sounds far too good to be true. if you are after something cheap then check out the manitou McLeod or if you don't mind a bit of cash then go for a CCDB coil either IL or CS
Posted : 02/06/2017 6:18 pm
