Who's good? usually go to TFT but they're booked up until late july
Theres an ad on ebay for fox servicing but i had a go and was quite pleased with the result. £10 for oil, £15 for seals.
Finephilly that's not a full service.
A lot of places will be very booked up, still recovering from being short staffed and in demand. If it's Fox then Fox UK might be quicker. Otherwise a semi local suspension service place might be able to get it in sooner. At pedals in Edinburgh we are booked up until about the same time as TF but might be able to get something in sooner, or if you are further north then Basecamp Suspension. For England, not sure! What has broken?
Sprung in the Forest of Dean or J-Tech near Shrewsbury (I think) have good reps.
Or do it yourself. My ham-fisted mate did his a while ago and nothing's fallen off so far...
Also you can try Slick and Slide suspension in Macclesfield.
Cheers all, nothing bust as such... gonna be away in Europe for a couple of months so just want full service done, should have go sorted sooner I guess - but hey ho
I changed the foam rings too and you should really change the crush washers or the oil leaks.
Changing the oil makes the most difference though as it gets thinner with use.
If its FOX suspension then FOX currently have a 2 week turn around
You got
lower seals/foam rings, crush washers
all air seals
all damper seals/glide rings/bladder
for £15?
No, £15 for the dust seals between lower legs/stanchions. Foam rings were extra. Air seals on mine are just rubber o rings which were ok. I reused the crush washers which i might get away with but should have put new ones on really. Left everything else. They are alps 32mm.
