Superstar/Stans Spo...
[Closed] Superstar/Stans Spoke Help
[#6370363]
So I've never replaced a spoke before, but one in my switch evo/stans crest wheels is totally seized.
I have proceeded to round it off unfortunately.
So, I need a new one - looks like I'm going to have to cut this one out.
The only problem is, what length?
I've tried the EVO hub details in the dt spoke calculator:
Pcd 58/45, flange 21/38, 2.5mm spoke, 541erd for 26inch crest.
It's a right side, 32 spoke, 2 cross - calculator says 294mm, which if I measure over the current spoke, takes it half way up the tyre.
Anyone help here? Cheers.
Posted : 28/07/2014 11:16 pm
Have you tried asking Superstar what length spoke they use? In my experience they quite helpful with technical questions.
Posted : 28/07/2014 11:44 pm
Erm, just take out one of the others, measure it, then buy 2? (Or put it back).
Posted : 28/07/2014 11:53 pm
Not sure how you've got 294 out of the DT calc?
With your numbers the Musson formula gives 250.16 left / 256.35 right.
HTH
Posted : 29/07/2014 8:06 am
